The Anker PowerCore Fusion is a portable power bank and wall adapter on sale for $25
The Anker PowerCore Fusion 5000mAh dual USB portable charger is down to $25.49 on Amazon, and this price is available in both white and red. Black is still selling for around $30, which is the street price for these wall adapters. They were actually selling as high as $36 for the last week or so, too, so this is an even better discount when compared to that. They do not drop directly much. Usually you need a code or something like with most Anker devices, so it's nice to just see the straight savings here with no hoops to jump through.
Anker Soundcore Life Q30 hybrid active noise-cancelling Bluetooth headphones
$59.99 $79.99 Save $20
These hybrid Bluetooth headphones reduce ambient noise up to 95% thanks to active noise-cancelling mics. The battery lasts up to 40 hours with ANC on or 60 hours with it off, and recharge via USB-C. Clip the $20 on-page coupon.
Anker Powerline II 6-feet USB-C to Lightning cable
$12.74 $15.00 Save $2
When using a USB-C power adapter (not included), you'll get the fastest possible charge for your iPhone. Plus you can seamlessly sync and charge your Mac. This is Apple MFi certified and lasts 12 times longer than other cables.
Anker Liberty Air 2 Pro true wireless earbuds Best Buy
$79.99 $130.00 Save $50
These earbuds have active noise-cancelling that's customizable with a simple app. You'll get a total of 26 hours of playtime with seven hours from a single charge and the rest from the charging case. Uses USB-C and has wireless charging.
Anker Soundcore Rave Neo portable Bluetooth speaker with LED lights
$84.99 $120.00 Save $35
Includes a rechargeable battery that will last for up to 18 hours and can charge other devices with the USB port. IPX7 rated for water resistance. The built-in LED lights will sync to the music you're playing. Connect multiple speakers together.
Anker Soundcore Liberty 2 Pro true wireless earbuds black
$49.99 $100.00 Save $50
They last for up to eight hours on a single charge with up to 32 hours total using the charging case. They have quick charge so you can get two hours after 10 minutes spent charging. They also charge via USB-C or a Qi wireless charger.
It's called the Fusion because it merges together two very important functions: a portable battery charger and a plug-in wall adapter. The portable battery charger part includes a built-in 5000mAh battery you can use anywhere. The LED indicators on the side will show you much juice is left.
If you get to a point where you've got a wall outlet at your disposal, you can just plug this charger in and use it to pull power straight from the outlet. That's convenient for both recharging the portable battery and continuously charging your favorite devices. Anker's PowerIQ and VoltageBoost technologies help detect what's been plugged in and deliver the fastest possible charge, although it doesn't support other things like Quick Charge.
The device has two USB-A ports you can use with any compatible device. It recharges via micro USB and comes with a cable for that. It also comes with an 18-month warranty and a travel pouch.
