Save $50 on Anker's discounted 19000mAh power bank bundle to charge or sync anywhere
Staying connected and powered up while on the go gets easier with Anker's PowerCore+ 19000 PD Portable Charger bundle, and now it's more affordable too. Amazon has this 3-piece bundle on sale for just $69.99 when you clip the coupon on its product page. That brings the set down to its lowest price ever for a total savings of $50 off; it was selling for $130 regularly just a few months ago. While you won't find Anker selling the PowerCore+ 19000 PD on its own, similar options sell for $60, but they can't do everything that this model can.
Anker's PowerCore+ 19000 PD Portable Charger has a secret ability. With a press of a button, it switches to Hub Mode and becomes a high-speed data syncing hub allowing you to connect its USB-C port to your computer so you can utilize its integrated USB ports however you need. It features one 27W USB-C Power Delivery port, a 15W USB PowerIQ 2.0 port, and a 10W USB PowerIQ port, which you can use to power up to three devices all at once. Anker states that its 19000mAh capacity gives it enough capacity to power an iPhone 8 up to six times before needing to be powered up again, while the Samsung Galaxy S9 can be recharged nearly five times.
Along with the PowerCore+ 19000, this set comes with Anker's 30W USB-C Power Delivery wall charger as well as a USB-C to USB-C cable so you can easily power up the power bank anywhere you go. Just the wall charger regularly sells for more than $25 on its own, while the cable can be found priced around $13 generally.
