Grab the first major discount on Anker's new Nebula Capsule Max portable projector
You are now subscribed
Your newsletter sign-up was successful
Anker's brand new portable projector, the Nebula Capsule Max comes with an early discount. Grab it at a deal price of $422.99 with code NEWCAPSU. Without that code, the projector sells for $470, and it will probably stay that price for some time. Anker has had a lot of success with previous generations of the Nebula projector, so it's a safe bet this one is just improving on the formula.
With the Nebula Max you'll get DLP technology with a 720p resolution and 200 ANSI lumen image. The image it creates can be as much as 100 inches large, and the darker the environment the better. Adjust the clarity instantly with auto-focus and keystone technology that gives you a sharp, rectangular picture from any angle in less than a second. The battery will last up to four hours so you can watch a full-length movie and some deleted scenes without even needing to get plugged in.
The Cabsule Max is powered by Android 8.1, which gives you access to all your favorite streaming apps like Netflix and Hulu. You can watch your favorite shows or movies anywhere you have access to Wi-Fi.
