Take up to 44% off Anker's Alexa-enabled car chargers and dash cams
As part of its daily deals, Amazon is offering some big savings on Anker's car-related accessories, including its Alexa-enabled car chargers and its great dash cams. Today's offers save you up to 44% off the regular price, and that makes the most affordable item in this sale drop down to just $12.74, which is completely impulse purchase territory.
There are five options for you to pick between. The most affordable is the Roav SmartCharge Spectrum Lite, which has two USB ports, one of which is Quick Charge 3.0. It offers a custom light ring around the top of it to easily let you match it to your car's lighting through an app on your phone. It normally sells for about $17, which means you can save just over $4 today. For a few more bucks, at just $15.99, you can upgrade to the PowerDrive 2 with LED that offers a full-size USB port and a USB-C Power Delivery port. It regularly sells for about $6 more, and if having a USB-C charger in your car is important to you, this is the one to get.
Anker's Roav Viva with car mount is down to just $41.99, which is 44% less than you could buy it for normally. This dual-USB car charger has Amazon's Alexa built right in, which means you can trigger Alexa like you would on an Echo device and have it complete phone calls for you, control your music, find the nearest gas station, and so much more. You can even use it to control your smart home devices so that you can turn on the lights before you get home, or have the garage door open as you pull up. This kit also comes with a car mount so that you have a safe place to store your phone while in the car, making it easier to use it for things like navigation.
Finally, there are two dash cam options available, one for $40.39 and the other is a bit more expensive at $74.98. The more affordable DashCam C2 offers total night vision, a wide-angle lens that can capture four lanes of traffic on video at the same time, 1080p video and more. The more expensive DashCam C1 Pro offers 2K video, built-in GPS records, smartphone compatibility to be able to view your videos instantly, and so much more. Regardless of which option you opt to grab, you'll want to make sure you add a microSD card to it in order to be able to record your full drive.
These prices are good for today only, though, so don't miss out.
Jared started off writing about mobile phones back when BlackBerry ruled the market, and Windows Mobile was kinda cool. Now, with a family, mortgage and other responsibilities he has no choice but to look for the best deals, and he's here to share them with you.
