Power up with Anker's 10W Qi Wireless Charging Pad at nearly 60% off
If you're on the hunt for a dependable wireless charger, look no further. Anker's mobile accessories are some of the best you can find on Amazon, and today its 10W Qi Wireless Charging Pad is on sale for only $12.99 when you enter promo code SDQH2512 during checkout. That saves you $17 off its regular price of $30 otherwise, and it's also the lowest we've ever seen this model reach.
This wireless charger is capable of powering compatible devices at up to 10W. Its LED ring lets you know when your device is charging, while its non-slip padding ensures your phone never falls off due to notification vibrations. This charger can even power up your phone through cases that are up to 5mm thick. MultiProtect technology provides safety features such as temperature control, surge protection, overcurrent protection, and more, while Anker's worry-free 18-month warranty is also included just in case it stops working suddenly or you encounter some other issue with its use. This wireless charger would be a perfect fit on any desk or nightstand, so much that you may just want to pick up a few in today's order.
You'll need a dedicated USB wall charger to keep this wireless charger powered up, and it'd be wise to grab one that can support its 10W charging capability.
Be an expert in 5 minutes
