Amazon Fire HD 8 (2022) vs. Fire HD 10 (2021): Which should you buy?
The best Amazon Fire HD for you.
Best Value Fire Tablet
The Fire HD 8 might be the best value tablet on the market, boasting smooth performance with Amazon's Fire OS and a surprisingly good display starting at $100. While it isn't quite as powerful as the HD 10, it offers all the same basic functionality at substantial savings.
For
- Great battery life
- Quick and easy access to Amazon services
- Lightweight and portable
- Built-in microSD card slot
Against
- More expensive than the previous model
- Performance is just okay
- You're still "stuck" with the Amazon App Store
Biggest and Best Fire Tablet
The Fire HD 10 takes everything great about the HD 8 and kicks it up a notch with better specs, a larger display, louder speakers, and the same Fire OS experience. It's a little pricier (though still affordable), but it's a much better option if your primary use for a tablet is media consumption.
For
- More RAM for faster performance
- USB-C charging
- Best-in-class parental controls
- Solid Bluetooth keyboard case in Productivity Bundle
- Microsoft Office 365 and 1 TB of OneDrive in Productivity Bundle
- Wireless charging option with HD 10 Plus
Against
- The cameras are still bad
- No official waterproof rating
- No built-in camera cover
- Google services not included
Amazon's Fire tablets are possibly the best tablets you can buy for the money. When you compare the Fire HD 8 vs. 10, you're getting incredible affordability and a ton of value in both. They run on Amazon's Fire OS and get their apps from the Amazon Appstore rather than the Google Play Store. They have full access to Amazon Music, Books, Video, Movies, Alexa, and everything else Amazon does, which, as it turns out, means you can do quite a lot.
Buying one of these tablets is a no-brainer for the budget-minded. The only tough part is deciding which one to choose.
Amazon Fire HD 8 vs. Fire HD 10: Value propositions
As you'd expect, the larger Fire HD costs more than, the smaller one, but there's more to break down here. At the top-end device of Amazon's excellent Fire tablet lineup, the Fire HD 10's display isn't just bigger; it's denser, with a 1920x1200 resolution versus the smaller HD 8's 1280x800 resolution. Both offer the same 32GB and 64GB storage options and are expandable when using one of the best microSD cards for Fire tablets.
Specs aside, we found that during the review of both the Fire HD 8 (2022) and Fire HD 10 (2021) offer relatively similar software experiences, with both tablets running on Amazon's Fire OS interface rather than a more traditional build of Android. You get all of your apps from the Amazon Appstore rather than the Google Play Store, which means a more Amazon-centric ecosystem.
Although similar, these tablets are meant for two different types of consumers. Bigger is better for movies. Get the small one for reading and games.
That's not necessarily a bad thing; both tablets come with unlimited cloud storage through Amazon, and Amazon hosts a bevy of excellent, exclusive content on its video services.
The OS is fueled by Alexa, who enables you to use voice commands to navigate the software and interact with the thousands of skills available. The digital assistant can now be called upon no matter what state the tablet is in, even if it's asleep.
Both tablets feature Show Mode, which gives you a visual representation of some of the things that Alexa helps you with. This includes showing the latest news reports, calendar appointments, weather updates, and viewing any smart security cameras you may have connected. However, the new split-screen function in the HD 10 makes multi-tasking a cinch as you can access and view two apps at once, like staying on top of social media updates while reading an article or watching a movie.
Header Cell - Column 0 | Fire HD 8 (2022) | Fire HD 10 (2021) |
Display | 8-inch IPS LCD (1280x800) | 10.1-inch IPS LCD (1920x1200) |
Storage | 32GB/64GB | 32GB/64GB |
MicroSD | Yes; expandable to 1TB | Yes; expandable to 1TB |
CPU + RAM | Quad-core 2.0GHz, 2GB RAM | Octa-core 2.0GHz, 3GB RAM |
Audio | Dolby Atmos dual stereo speakers, 3.5mm audio jack | Dolby Atmos dual stereo speakers, 3.5mm audio jack |
Rear camera | 2MP, 720p video | 5MP, 720p HD video |
Front camera | 2MP | 2MP |
Dimensions | 7.94 x 5.40 x 0.37 inches (202x137x9.7mm) | 9.73 x 6.53 x 0.36 inches (247x166x9.2mm) |
Weight | 337g | 465g |
Colors | Black, Denim, Rose | Black, Denim, Olive, Lavender |
Amazon Fire HD 8 vs. Fire HD 10: Which should you buy?
When choosing between the Fire HD 8 vs. 10, you should think about what you'll be doing most with it. If you mainly want an e-reader for Amazon's enormous Kindle library, with the occasional video or music playback, the Fire HD 8's smaller form factor may be the better choice. It's half the price of the HD 10, and aside from weaker speakers and a slightly slower processor, you're not missing much.
Buy the HD 8 as an e-reader and light browsing device. Buy the HD 10 as a video streaming device.
If instead, you plan on watching a lot of videos and movies on your tablet, the larger Fire HD 10 is the better choice. The larger, denser display, strengthened with aluminosilicate glass, provides a much better viewing experience, and you'll appreciate the louder speakers. It's more expensive than the HD 8, but it's still a bargain compared to virtually every Android tablet on the market. And it's smaller, lighter, and brighter than the previous-generation 2019 edition HD 10 tablet.
No matter which tablet you decide on, you'll be getting a surprisingly great device for the money. They're both great for media consumption and light gaming, whether you're buying for yourself, your kids, or as a gift.
Good performance and price
The Fire HD 8 is cheaper than the HD 10 and offers a nearly identical experience. The smaller size makes it a great e-reader, and the dual stereo speakers are good enough for playing back audiobooks, music, and movies.
Among the best under $200
If you plan on watching a lot of movies on your tablet, the Fire HD 10 is the clear winner. Its display is larger and higher density than the HD 8, it comes with more onboard storage, and the speakers are louder and clearer.
Be an expert in 5 minutes
Camille Sanghera is a UX writer and copywriter for global brands as well as an author of self-help books. Although she has lived and traveled internationally, Camille is originally from British Columbia, Canada. She merges over 10 years of writing experience with a love of words to bring authenticity and human connection to every project. When not writing, Camille can be found exploring nature with her dog, sketching to music, or laughing with loved ones.
You can chat with Camille on Instagram at @projectpvo.
- Hayato Huseman
- Jeramy JohnsonEditor-in-chief
- Christine PersaudContributor
