Amazon Fire HD 8 Kids vs. Fire 7 Kids: Which tablet for your kid?
Amazon does a great job of continually updating its Fire tablet line-up and the Kids tablets, and when looking at the Fire HD 8 Kids vs. 7 Kids, those updates are quite welcomed. These tablets offer a relatively low-cost option of tablets for kids that they'll love, and parents can feel comfortable handing them over. The parental controls that come on the Fire Kids tablets are some of the best in all tech, and the curated kid's content is expansive enough for kids of all ages. However, on the surface, the Fire HD 8 Kids and the 7 Kids only have a 1-inch difference, so which should you choose?
Amazon Fire HD 8 Kids vs. Fire 7 Kids: Size isn't the only difference
Amazon Fire HD 8 Kids (2022) Blue
(Image credit: Amazon)
The Fire HD 8 Kids sits squarely in the middle of Amazon's Fire tablet lineup for children, but the capability is at the top. While it doesn't have the same screen size or resolution that the Amazon Fire HD 10 Kids Pro behemoth does, the smaller tablet does have that same raw power. Though the 7-inch model doesn't have impressive specs, it still gets the fantastic parental controls and children's content as its more expensive counterparts.
Even though these two tablets look very similar, some important variations make a significant difference in what the overall experience will be like. Depending on the age of your child, they may or may not notice any difference. However, as your child ages and experiences more capable pieces of technology, the less advanced internals of the 7-inch Fire 7 Kids tablet will start to show.
Swipe to scroll horizontally
Header Cell - Column 0 Fire HD 8 KidsFire HD 7 Kids
Weight18.3 ounces15.1 ounces
Display8-inch; HD7 inches
Dimensions 8.7 x 7.1 x 1.1 inches6.4 x 7.9 x 1.1 inches
Storage32GB, 2GB RAM16GB or 32GB, 2GB RAM
Expandable StorageUp to 1TBUp to 1TB
Screen Resolution1280x800 (189 ppi)1024x600 (171 ppi)
Battery lifeUp to 13 hours of multimediaUp to 10 hours of use
Camera2MP front and rear-facing cameras with 720p video recording2 MP front and rear-facing cameras with 720p HD video recording
Alexa enabledOff by defaultOff by default
ColorsBlue, Purple, Disney Princess, and Disney Mickey MouseBlue, Purple, and Red
AudioDual speakers with Dolby AtmosMono speaker
CaseKid-safe case includedKid-safe case included
Parental ControlsYesYes
Amazon Kids+One year includedOne year included
PortsUSB C, 3.5mm headphone jackUSB-C, 3.5mm headphone jack
Warranty2-year2-year
If we start with the part of the tablet that will be used every time you turn it on — the display — the differences are minor. The improved display on the 8-inch version is worth considering because as your child grows and learns, the higher PPI (pixels per inch) matters — especially when they are learning to read. The higher resolution means that not only is the fun stuff they do on the tablet going to look better, but so is the text they are trying to read.
Getting the best viewing experience possible is important for little eyes to ensure there's less squinting.
Moving on to the other part of the entertainment experience that's improved on the Fire HD 8 Kids versus the smaller 7-inch option is the speakers. On the larger tablet, you get dual speakers with Dolby Atmos support. This means that there will be less straining to hear what's being played on the tablet. Don't worry, parents; there is still a headphone jack.
When we look at what's below the surface, the increased RAM and built-in storage of the 8-inch model means that the faster processor will have no problem handing programs for your child. The tablet will be a much smoother experience, which is vital so that your young child doesn't get discouraged thinking they didn't do something right.
Amazon Fire 7 Kids
(Image credit: Chris Wedel/Android Central)
The increased internal specs also mean that the tablet will be able to keep up with your child's demands as they grow up. This allows them to continue using the tablet longer, saving them money. I have a 7-year-old that used a Fire HD 8 Kids from two years ago, and while it still does fine for most things, its lower specs are starting to show some age in the speed category. He now uses the Amazon Fire HD 8 Kids Pro, which matches the standard model in all ways, except it has a more mature interface and different cases. You can check out our guide on Amazon Fire Kids tablets to see the differences between the regular and Pro models.
When you can afford to buy technology with better specs, it's good to do so if you intend to use it for years to come.
While the Fire 7 Kids doesn't have the best specs, it still has some of the best software — as all of the Amazon Kids tablets share that software and performed quite well during our review. Packed with a wide range of parental controls, you can control what content your child can access when they can access it, and for how long.
Amazon's Kids+ is the place where your child can access over 20,000 books, movies, TV shows, apps, and games that have all been curated specially for kids — and it's free for the first year. With parental controls, you can set the age range of content your child gets to see from this library.
On top of the great software, Amazon is also helping to protect the hardware. Each Kids tablet comes with a fun-colored foam rubber case with a kickstand that makes holding the tablet easier and keeping it safe. However, should the tablet get damaged, it's backed by a two-year "worry-free" guarantee in which Amazon will replace the device for free should something happen to it.
Amazon Fire HD 8 Kids vs. Fire 7 Kids: Which should you buy?
Amazon Fire HD 8 Kids (2022) Disney Princess
Each of these tablets comes with enough great content that your child will likely be happy with either, making them two of the best Android tablets for kids. My son was just excited to have a tablet he could call his own. That being said, if you can afford the additional cost of the Fire HD 8 Kids, it'll be worth it. From its improved display, better internal hardware, and not to mention the additional five hours of battery life over the 7-inch model, the larger tablet is the way to go.
Because it has improved hardware over its smaller sibling, the 8-inch option will be a device that will age better than the Fire 7 Kids. However, if you are looking for a tablet that you can start your child off with, and the price is a primary consideration, the 7-inch version will still get the job done. Since each tablet offers the same excellent software experience, the content and parental controls are still there.
Chris Wedel
Smart Home Writer
Chris Wedel is a fan of all things tech and gadgets. Living in rural Kansas with his wife and two young boys makes finding ways to get and stay online tricky. By utilizing his years of experience with the tech and mobile communications industries — success is assured. When not conquering connectivity challenges and testing new gadgets, he enjoys cruising a gravel road in his UTV with some good tunes.
Read more
Samsung Galaxy Tab A9 Plus Kids Edition lifestyle render
Best Android tablets for kids 2025
Redmi Pad Pro with keyboard case on a table
What's the best cheap tablet for Android in 2025? I tested over 50 devices and here are my results
Best Android Tablets hero
Best Android tablet 2025
Amazon Kindle Scribe
Best Amazon Kindle e-reader 2025
The Honor Pad V9 with its box alongside the Honor Pencil 3
Honor Pad V9 review: It's a good time with more Google than ever
Child wearing a Ticktalk 4 kids smart watch
Best kids smartwatch 2025
Latest in Tablets
Amazon Kindle Scribe on desk
Unbelievable! The Kindle Scribe soars to its lowest price EVER during Amazon's Big Spring Sale
Kobo Libra Colour review
Kobo Libra Colour review: The obvious upgrade to the Kindle Oasis
Google Pixel Tablet in vertical mode
The Google Pixel Tablet has crashed back to its Black Friday price, days before Amazon's Big Spring Sale
Xiaomi Pad 7 against colorful background
Xiaomi Pad 7 is a convincing iPad Air clone that costs half as much
Honor MagicPad 2 review
Honor MagicPad 2 review: This mid-range tablet has a unique OLED advantage
Galaxy Tab S10 FE Plus render
Leaked Galaxy Tab S10 FE Plus renders confirm a large display and a familiar design
Latest in Versus
Using Google Circle to Search on a Samsung Galaxy S24 Ultra
Visible vs. T-Mobile: Which wireless carrier is the better choice for you?
Comparing the size and shape of the Samsung Galaxy S24 Ultra versus the Samsung Galaxy S25 Ultra
Samsung Galaxy S25 Ultra vs. Galaxy S24 Ultra: A flagship face-off
All four Samsung Galaxy S25 Plus colors from the side
Samsung Galaxy S25 vs. Galaxy S24: Worth the upgrade?
NVIDIA Shield TV Pro against green background
Google TV Streamer vs. NVIDIA Shield TV Pro 2019: Two solid streaming options
The Moto G Stylus 5G 2024 next to the Stylus 5G 2023
Visible vs. AT&T: Which carrier is right for you?
OnePlus 13 back camera
OnePlus 13 vs. OnePlus 12: Is it worth the upgrade?
