Amazon Echo Show 10 vs. Nest Hub Max: Which smart display is better?
The Nest Hub Max and Echo Show 10 (3rd Gen) are two 10-inch high-end smart displays that give you all the best features Google and Amazon have to offer. We rated both displays highly in our reviews, but both have distinct perks (and drawbacks) that'll make one a better fit for you than the other.
Amazon Echo Show 10 vs. Nest Hub Max: Comparing tracking and camera tech
Echo Show 10 (right) and Nest Hub Max (left)
(Image credit: Jeramy Johnson / Android Central)
Both the Echo Show 10 and Nest Hub Max can track your location as you move around a room. For the Nest Hub Max, this is mostly limited to video calls — the 6.5MP camera has a 127-degree wide-angle lens that can digitally zoom in on your face as you move, so the person on the other end of the call doesn't lose sight of you even when you're busy. Of course, this only works to an extent since the Max cannot rotate if you move out of its line of sight.
Article continues below
With the Echo Show 10, no matter where you go in the room, you'll never lose sight of what you're watching or who you're talking to.
The Amazon Echo Show 10's 13MP camera not only tracks you during calls, but moves its screen to follow you thanks to its motorized, rotating top. During setup, you'll map the room to ensure the screen can fully rotate to follow you; if there's an obstruction, it'll sense it before hitting it, ask you if it's temporary or permanent, and adjust its rotation path accordingly. Once set up, it'll sense and track you around the room, so you'll always have a direct line of sight on whatever info Alexa is giving you. In our testing, its tracking tech was spot-on.
The Echo Show 10 screen can turn 175 degrees in either direction from its default position, meaning it can face backward but can't do a full circle. You can also move or tilt the screen manually. When rotating, the brushless motor is virtually silent, so the noise won't annoy you; but you can also tell Alexa to stop tracking you if the movement bothers you for other reasons.
Fact is, even without the rotation gimmick, the 13MP camera is really helpful for people who work from home or want to video call distant relatives. In our Echo Show 10 (3rd Gen) review, we found the camera captures a very crisp video feed, useful for group calls through the Alexa app. You can also take photo booth selfies with fun stickers, then automatically upload them to Amazon Photos.
We tested the tracking capabilities of both smart displays. Our Nest Hub Max reviewer said that the track and zoom feature worked best if you are within six to eight feet of the display in proper lighting. As for the Echo Show 10, it can track people fully up to ten feet away.
Amazon Echo Show 10 vs. Nest Hub Max: Privacy and data
Amazon Echo Show 10 Backyard
One unique Nest Hub Max feature is facial and voice recognition. Google's Face Match and Voice Match enable the smart display to recognize multiple users as different people. If you say "Hey Google", the Max will register your identity and pull up your Google account-related notifications, personal Spotify playlists, and so on. However, if it sees and hears your roommate, spouse, or child ask a question, it'll display all of their Google account notifications instead.
The newest feature added in 2022 is Look and Talk, where Face Match detects you approaching the Nest Hub Max and lets you speak to it without having to activate it with "Hey Google." And Google may soon add the option for custom wake-up phrases so you can say something else to activate your Nest from across the room.
Amazon also has optional Alexa Voice Profiles to give you personalized responses, though these Profiles must all be tied to a single Amazon Household. It doesn't have any facial matching, though; quite the opposite, it uses algorithms to scramble any captured video so no identifiable features are ever captured.
In general, both smart displays (and their companies) take privacy more seriously than they used to. Each has a physical mute switch and physical camera shutter, so you can ensure that nothing is being recorded. Neither company stores recordings by default anymore, and if you do enable recordings, you can order Alexa or Google Assistant to delete the previous recording. Both are "always listening", but they will only record or respond to the wake word. You can use Amazon's Privacy Hub or Google Assistant settings to delete all stored audio recordings.
Finally, both companies promise to keep your data private by processing visual information on the device, without relying on the cloud. The Nest Hub Max processes Face Match locally, as does the Echo Show 10 with its person recognition and tracking. No video recordings are sent to the cloud unless you activate security camera features.
Amazon Echo Show 10 vs. Nest Hub Max: Security and smart home tech
Video call on the Google Nest Hub Max
Both of these smart displays serve similar roles for smart home security. With either, you can remotely access its camera from your app and get a live view of your home, set them up to send you motion or sound alerts, or speak to someone through the display remotely with two-way audio. Or, if you own other security cameras and pair them to Alexa or Google Home, you can order your assistant to pull up their feeds on your smart display.
If you want them to do more for your home security, you'll need to pay for a security subscription. With Nest Aware, your Nest Hub Max can continuously record footage to the cloud and alert you if an "unfamiliar face" enters the room. Or, with Alexa Guard Plus, you can put your Echo Show 10 in "Sentry mode" and have it periodically scan the room for intruders.
Of the two, the Echo Show 10 has more robust security features. Besides sentry mode, you can set up occupancy or vacancy-triggered routines: these either occur when unexpected motion is detected, or when no one is detected nearby. For instance, you can trigger Alexa-compatible smart lights to turn on or an alarm if your camera spots someone. It can alert you if it hears a fire alarm or glass breaking. Plus, there's the obvious fact that the 13MP camera will capture clearer footage than the Nest Hub Max's 6.5MP camera.
These smart displays have some useful security features, but a dedicated security camera will be both cheaper and more effective.
How do these smart displays compare to the best indoor security cameras in specs and features? Not very favorably. They're mainly useful for daytime monitoring when away from home, but neither can capture night-vision footage. Both rely on a monthly security subscription — the Nest Aware subscription for Google devices, or the Ring Protect subscription for Amazon devices, which bundles in Amazon Guard Plus for free. Frankly, you can buy a cheap indoor security camera that offers much better protection at a fraction of the price; either smart display is more useful to watch security footage than to generate it.
Amazon Echo Show 10 vs. Nest Hub Max: Sound quality and specs breakdown
Our Nest Hub Max reviewer praised its fantastic audio quality. We were impressed by its camera tracking for video calls, as well as its mic quality for picking up commands even when the music is loud, but lamented that the rear-firing speakers caused some audio balancing issues with bass.
As for the Echo Show 10, we knew it had a slightly larger woofer and dual tweeters, but didn't know how it would perform in practice, especially as it rotated around. In practice, our reviewer raved about the Echo Show 10 speakers as some of the best Alexa speakers available. Loud and clear, the audio literally follows you around the room thanks to AI tech that focuses the speaker sound in your direction at all times.
AI smarts also help the Echo Show 10 to respond to voice commands twice as fast as the Echo Show 8. While we don't have a specific comparison between the Echo and Nest in this area, it's safe to assume that a brand-new device with two processors will have more power and speed than a 2019 device with just one chip. You can see how else these devices compare in the table below:
Swipe to scroll horizontally
Header Cell - Column 0 Amazon Echo Show 10Nest Hub Max
Price$250$230
ProcessorMediaTek 8183 main processor, plus second processor with Amazon AZ1 Neural EdgeAmlogic T931
Smart AssistantAlexaGoogle Assistant
Touchscreen10.1-inch HD10-inch HD
Speakers2x1.0-inch tweeters, 1x3.0-inch woofer2x.7-inch 10W tweeters, 1x2.95-inch 30W woofer
Camera13MP + Shutter6.5MP with 127º FOV
Privacy controlsPhysical cover for camera, electronic switch for micPhysical cover switch for mic and camera
WiFi802.11 a/b/g/n/ac (2.4GHz/5GHz), dual-antenna (MIMO)802.11 b/g/n/ac (2.4GHz/5GHz)
BluetoothA2DP, AVRCP5.0
Chromecast built-inNoYes
Smart Home IntegrationZigbee + SidewalkWorks with Google Assistant
Moving cameraBrushless motor with +/- 175° rotation physically rotates deviceCamera zooms in and moves to track person speaking (the Nest itself doesn't move)
Face MatchNoYes
Voice MatchNoYes
Gesture controlsNoYes
PhotosCan display Amazon or Facebook photos on home screenCan display Google Photos on home screen
Low Power ModeUses less power when not in useDims screen to ambient lighting when not in use
Security system compatibilityWorks with Guard PlusWorks with Nest Aware
Can you delete old recordings?YesYes
Size9.89 x 9.06 x 6.77 inches9.85 x 7.19 x 3.99 inches
Weight5.64 lbs2.91 lbs
Amazon's AZ1 chip, adaptive color photos, MIMO Wi-Fi support, and Low Power Mode make it clear that the older Nest Hub Max needs an upgrade.
Alexa's dual processors aren't just for voice commands. The Echo Show 10 has a cool new feature called adaptive color, which takes your Amazon Photos on the home screen and "blends on-screen colors with the tone and hue of the room environment for more natural images". The Nest Hub Max also lets you put Google Photos on the home screen, and dims the display to the same level of brightness as your room when not in use, but doesn't play with the photo settings.
With either display, you get Bluetooth support for streaming from your devices and dual-band Wi-Fi for voice assistant command processing — though only Amazon has MIMO support and dual antennas. Where the Nest Hub Max shines is its built-in Chromecast, which provides faster connectivity than Bluetooth syncing can typically offer.
Along with Face and Voice Match, the Nest display also has some limited Quick Gesture support, such as holding up your hand in front of the camera to pause the music, without even having to make a verbal command.
The Echo Show 10 is made of 30% post-consumer recycled plastics and 100% post-consumer recycled fabric and aluminum thanks to Amazon's new focus on environmental efficiency. It also has a new Low Power Mode setting for all of its new Echo devices that use less electricity whenever the Echo isn't being actively used.
Amazon Echo Show 10 vs Nest Hub Max: Which should you buy?
Amazon and Google's latest smart displays have comparable pricing, security camera settings, robust smart home support for third-party devices, HD resolution, auto-facial tracking so people you call get a constant close-up of you from afar, and several other features in common.
The Echo Show 10 has superior specs, but stick with the Nest Hub Max if you prefer Google Assistant to Alexa.
Where the Echo Show 10 stands out, of course, is in its mobility. So consider where in your home you would place such a smart display. On a kitchen island, for instance, having a rotating base would be incredibly useful. If you would place it against a wall, or somewhere where the Nest's 127-degree lens would capture everything anyway, you may not really need that feature.
Ultimately, you can make a case for either as the best smart display, based on where you fall on the Google Assistant vs Alexa debate. But the Echo Show 10 benefits from more powerful processing for voice commands, plus a far-superior camera with a physical shutter for privacy. By comparison, the Nest Hub Max is more dated by now, and could certainly benefit from an upgrade.
Michael L Hicks
Senior Editor, Wearables & AR/VR
