This Amazon deal saves you 50% on a smart power strip with built-in USB ports
With all the new devices in our lives, you should have a power strip at home that can handle them appropriately. This Nooie Smart Power Strip has USB ports built-in so you can get rid of your bulky wall chargers that won't plug in beside each other and plug USB charging cables in directly instead. Today you can snag one at Amazon for just $24.99 when you first clip the coupon on its product page and then use promo code PWCQLHFN during checkout. That'll save you 50% off its usual cost of $50.
Nooie smart power strip and surge protector
$24.99 $50.00 Save $25
Stack the code with the $5 off coupon. The strip includes protection from surges and overloading. It works with Amazon Alexa and Google Assistant. You can schedule it to turn on and off, too, with an app. Has 4 outlets and 4 USB ports.
Nooie Wi-Fi Indoor Home Security Camera
$19.99 $24.99 Save $5
This 720p HD home security camera live streams its footage 24/7 to an app on your phone so you can always know what's going on at home.
The strip includes four AC outlets and four USB ports. The outlets are spaced nicely apart so you can use those larger power adapters when necessary. The strip includes overload and surge protection. It can absorb a large amount of sudden energy like during a power outage or storm and keep your electronics safe. The circuit breaker will automatically break off when it detects events like that.
You will want to connect the strip to your 2.4 GHz Wi-Fi network. From there you can download the free app that comes with it or connect it to your smart home. It works with both Amazon Alexa and Google Assistant so you can control whatever is plugged in with your voice. The plugs can even be controlled individually so it's not an all-or-nothing situation for the whole strip. Use the app to control them all remotely, turning them on or off even while you're away from home. Add lights, fans, heaters, and other appliances and then set specific times when they need to be used.
The 3.28-foot power cord uses heat-resistant materials so it will last a long time and won't fray or wear down. You can also mount it to the wall or in any position you prefer. The strip comes with a two-year warranty and a lifetime of tech support.
Shipping at Amazon is free on orders totaling $25 or more, or with an Amazon Prime membership. If you've never been a member before, you can start a free 30-day trial to change that today.
