This Alexa-enabled Smart Temperature and Humidity Sensor by Govee is now 35% off
Start monitoring temperature and humidity in your home from your smartphone using Govee's Alexa-Enabled Smart Temperature + Humidity Sensor. With its Alexa integration, you can even ask Alexa to check on the temperature or humidity for you using a compatible Echo device, or look for yourself on its built-in LCD screen. This smart device regularly sells for $70 at Amazon, but today you can snag one for only $45.49 as part of a wider smart home sale.
Govee's Alexa-enabled Smart Temperature + Humidity Sensor features an integrated Swiss-made SHT30 sensor for high precision monitoring, with the temperature gauge accurate within .3 degrees Celsius and humidity within 2% relative humidity. That allows for super-accurate data so you won't have to worry about false or imprecise readings.
Having one of these handy could let you know if your child's nursery becomes too hot or if your basement gets too humid, and you'll be able to find out by quickly looking at your smartphone whether you're at home or not. The sensor even has a feature that will send an alert to your phone if the temperature or humidity crosses out of the preset range you've selected in the app. There's also a data storage function where you can keep 20 days of on-board data and up to two years of information utilizing cloud storage. Plus, Govee makes it easy to export the data as a CSV file.
You'll want to make sure you have an Echo device around the house, such as an Echo Dot, to start having Alexa read you this sensor's findings. If that's not such an important feature in your eyes, you can find a similar model of Govee's Temperature + Humidity Sensor which isn't Alexa-enabled for just $20.
Shipping is free on this item at Amazon, though you'd recieve your order even faster with Amazon Prime. If you're not a member already, consider signing up for a free 30-day trial to score free two-day shipping, exclusive members-only discounts, and more.
Be an expert in 5 minutes
