Add some smart lighting with these 4 multi-color dimmable LED bulbs down to $26
Grab a 4-pack of Aoycocr BR30 dimmable LED multi-color smart bulbs at a sale price of $25.91 with code 40RUXA1L on Amazon. These bulbs usually sell for around $53 and do not drop lower than that price. More often than not they sell for more than that price. So you're saving $10 and getting a rare discount.
Those savings are unique for Prime members. You can still use the code to save some money if you don't have Prime, but you'll end up paying a few bucks more in the end.
The Aoyococr bulbs do not require a lot of setup. Just install them like any other light by screwing them in. Then download the Smart Life app and pair your bulb. Follow the instructions, connect to your Wi-Fi, connect to your smart home, and get to customizing. The app gives you the ability to create scenes, set routines, change the colors, set a schedule, and even more.
If you do want to control these bulbs with your voice, you'll just want something like the Amazon Echo Dot. And those are still on sale right now for $24.99 at Woot. The bulbs also work with Google Assistant.
These are BR30 bulbs, which means they aren't designed like regular A19 bulbs that fit in standard lamps. The BR30 are directional flood lights that work best when placed in ceiling fixtures or used for recessed lighting. However, Aoyococr also has multi-color A19 bulbs going for around $36 if that's what you need.
Choose from over 16 million colors when deciding just what color you want your new smart bulbs to be. You can even tune the color temperature from 2700K warm light to 9000K daylight. Match with any other bulbs you have around the room. They are also dimmable from 10% to 100%, which you can adjust without connecting them to a dimmer.
The bulbs should last as long as 22 years with a lifespan of 25,000 hours. Exactly 100 customers have given these bulbs 4.7 stars out of 5 on Amazon.
