This add-on eufyCam 2 wireless home security camera is 15% off at Amazon
If your house is already set up with the new EufyCam 2 wireless home security system, Amazon has a stellar deal on the add-on EufyCam 2 camera that you won't want to miss. For a limited time, it's down to just $127.49, saving you over $20 off its regular price of $150. Today's deal marks one of the best prices it's ever reached.
You'll need the eufy HomeBase 2 to operate this camera. You should have one if you already own a EufyCam 2, but if you're new to the system, you can pick up the EufyCam 2 2-camera set on sale for $297.49 currently. It includes the HomeBase 2 so you'll have everything you need to get started.
Eufy cordless stick vacuums and robot vacuum cleaners
As low as $140
Choose from a cordless stick vacuum or a robot vacuum. The cordless vac includes 120AW suction power for 8 minutes or 25 minutes in standard mode. Helpful for getting into tight spaces. The robot has 1300Pa suction and lasts up to 100 minutes.
Eufy Security Wi-Fi 2K resolution video doorbell
$119.99 $160.00 Save $40
You'll get a wireless chime you can use somewhere else in the house to hear the door wherever you are. Has a 2K resolution image with advanced HDR and distortion correction. Includes two-way audio, motion detection, and smart alerts.
Eufy RoboVac 15C Max Wi-Fi connected robot vacuum cleaner
$175.99 $ Save $
Comes with super strong 2000Pa suction so it can pick up even stubborn dirt. BoostIQ feature will even boost the suction when you need it. Lasts for up to 100 minutes. Use the EufyHome app and connect it to your smart home for more control.
Eufy Spaceview Security by Anker baby monitor camera bundle
$129.99 $170.00 Save $40
Has a large 5-inch 720p display for a sharp picture. Let's you see everything your little troublemaker is doing. Can pan 330-degrees and tilt 110-degrees so you can see the whole room. Get instant alerts. Has a range up to 1,000 feet.
Eufy Security SpaceView 720p video baby monitor with night vision
$109.99 $160.00 Save $50
Has a large 5-inch 720p display for a sharp picture. Let's you see everything your little troublemaker is doing. Includes a wide-angle lens for when your baby starts moving around more. Get instant alerts. Has a range up to 1,000 feet in open area.
This is the second-generation of Eufy's home security system, and it was only just released, so seeing a deal this good is pretty significant. Plus, the EufyCam 2 greatly improves on the first-generation EufyCam E in a number of ways. You'll get more advanced A.I. powered facial recognition software that helps prevent false positives. The new EufyCam 2 can tell the difference between familiar faces, objects, dogs, birds, and other things that the old EufyCam E might have sent you an alert about. You'll also get a better IP rating for withstanding weather. The new EufyCam 2 has an IP67 rating, which means it is a lot more resistant to water than the previous generation's IP65 rating. It also comes with an 8x digital zoom, which is something the original does not have.
In addition to all of that, the camera has 16GB local storage that can store up to a year's worth of video, a battery that can last 365 days on a single charge, 1080p video recording, night vision that works up to 25-feet away, two-way audio, and a 140-degree wide angle lens so you can capture all around your home.
The camera also has sophisticated smart home integration. You can connect the camera system to your Wi-Fi and control it from your smartphone. You'll also be able to use voice commands through Amazon Alexa, Google Assistant, and Apple's HomeKit, which is another new feature for the series.
