Add Anker's PowerWave Base fast wireless charger to your desk at its best price yet
Anker Powerwave Base Lifestyle
If you have a smartphone that's Qi-compatible but you're still not using wireless charging, you've been missing out. Chargers like Anker's PowerWave Base Wireless Charging Pad are extremely affordable these days, so you don't even save much by choosing traditional charging — if anything at all. With today's deal, you can start wireless charging for only $10.99 and save $3 off the usual cost of this well-reviewed charging accessory. All you have to do to score the 22% saving is to enter code AKEDM255 during checkout.
Anker Soundcore Life Q30 hybrid active noise-cancelling Bluetooth headphones
$59.99 $79.99 Save $20
These hybrid Bluetooth headphones reduce ambient noise up to 95% thanks to active noise-cancelling mics. The battery lasts up to 40 hours with ANC on or 60 hours with it off, and recharge via USB-C. Clip the $20 on-page coupon.
Anker Powerline II 6-feet USB-C to Lightning cable
$12.74 $15.00 Save $2
When using a USB-C power adapter (not included), you'll get the fastest possible charge for your iPhone. Plus you can seamlessly sync and charge your Mac. This is Apple MFi certified and lasts 12 times longer than other cables.
Anker Liberty Air 2 Pro true wireless earbuds Best Buy
$79.99 $130.00 Save $50
These earbuds have active noise-cancelling that's customizable with a simple app. You'll get a total of 26 hours of playtime with seven hours from a single charge and the rest from the charging case. Uses USB-C and has wireless charging.
Anker Soundcore Rave Neo portable Bluetooth speaker with LED lights
$84.99 $120.00 Save $35
Includes a rechargeable battery that will last for up to 18 hours and can charge other devices with the USB port. IPX7 rated for water resistance. The built-in LED lights will sync to the music you're playing. Connect multiple speakers together.
Anker Soundcore Liberty 2 Pro true wireless earbuds black
$49.99 $100.00 Save $50
They last for up to eight hours on a single charge with up to 32 hours total using the charging case. They have quick charge so you can get two hours after 10 minutes spent charging. They also charge via USB-C or a Qi wireless charger.
The pad provides 10W high-speed charging for devices that support it such as Samsung's line of Galaxy devices, while iPhone models charge at 7.5W. It gives a 5W charge for any other Qi-enabled phone or device. The LED indicator lets you know the charging status at a glance, including whether or not the phone's case is too thick or there's something else between the phone and the charger.
Luckily, this wireless charging pad works with most cases up to 5mm thick, but any metal or cards in the back of the phone will prevent charging. The pad's rectangular design makes it really easy to get the right alignment of your phone so it gets the optimum charge. There are non-slip pads on the underside of the pad to keep it stationary as well as a rubber ring on the top so your phone stays put, too. There are also vents under the pad to dissipate heat.
Existing users rate it highly with an average of 4.6 stars out of 5 based on over 200 reviews. Anker also backs it up with an 18-month warranty. Though it includes a USB cable, this pad does not come with a USB wall adapter to plug into. You'll want one with Quick Charge 3.0 if you plan to use its fast-charging tech, so grab that additional accessory to ensure you're getting the fastest charge.
Of course, it can be difficult to know which wireless charger to go for given how many there are on the market. That's exactly why we put together our list of the best wireless charging pads in 2020 to help you figure out which is the right one for you.
Shipping at Amazon is free on orders totaling $25 or more, or with an Amazon Prime membership. You can try one out for 30 days for free to score free two-day shipping, access to Prime Video, and more.
Adam Oram is a Senior Writer at iMore. He studied Media at Newcastle University and has been writing about technology since 2013. He previously worked as an Apple Genius and as a Deals Editor at Thrifter. His spare time is spent watching football (both kinds), playing Pokémon games, and eating vegan food. Follow him on Twitter at [@adamoram](https://twitter.com/adamoram).
