Will Galaxy Z Flip 3 cases fit the Z Flip 4?
You're stuck with a single option if you need a case that fits the Flip 4 and Flip 3.
Unfortunately, almost all Galaxy Z Flip 3 cases are incompatible with the Z Flip 4 and do not fit the new Samsung foldable.
You can't swap cases between your Flip 4 and Flip 3
Although Samsung only made incremental changes when bumping up the Z Flip 3 to the Flip 4, the shape and size specs of both foldables are not identical. Small differences such as the width of the bezels and camera placement make it difficult to use a Flip 4 case interchangeably with your Flip 3 or vice versa.
Category | Samsung Galaxy Z Flip 4 | Samsung Galaxy Z Flip 3 |
Dimensions (unfolded) | 165.2 x 71.9 x 6.9mm | 166 x 72.2 x 6.9mm |
Dimensions (folded) | 84.9 x 71.9 x 15.9-17.1mm | 86.4 x 72.2 x 17.1mm |
It is a darn shame that you can't use your Z Flip 3 case on your next-gen flippable from Samsung. Not only is a Flip 4 case more expensive than an average phone cover, but purchasing a new accessory and discarding the older one also creates more plastic waste which collects in a landfill somewhere, poisoning our planet.
If you are extremely committed, there is one option available. Speck is the only brand that we have come across so far with a Samsung Galaxy Z Flip 4 case that is backward compatible.
You can get the basic Speck Presidio Perfect Clear Case for your Galaxy Z Flip 3 and Flip 4. It fits both devices nicely as we tested and you can choose between a bare-bones variant or a glittery option.
Speck's Presidio Clear is by no means the most protective cover, but it does feature an antimicrobial coating that kills germs as well as drop protection from a height of 13 meters. We were also impressed by the solid hinge mechanism of the Samsung Galaxy Flip cover.
Backward compatible
This clear case from Speck fits both the Samsung Galaxy Z Flip 4 and the Z Flip 3. Opt for the completely see-through version or jazz things up a bit with the glitzy variant, the choice is yours.
Be an expert in 5 minutes
Namerah enjoys geeking out over accessories, gadgets, and all sorts of smart tech. She spends her time guzzling coffee, writing, casual gaming, and cuddling with her furry best friends. Find her on Twitter @NamerahS.
