Save up to $120 while securing your home with a complete Ring Alarm kit
These Ring Alarm kits can offer everything from keypads to motion sensors.
Home security products are becoming increasingly popular every day, and Ring has been one of the leaders in the space for quite a while. Ring covers a wide range of devices to help you secure your home, from their video doorbells to security cameras to lights and sensors. But for some, it can be confusing to piece together a complete system. Thankfully there are some helpful bundles to get you started or completely outfit your home, and because it's Black Friday, there are some excellent Ring Alarm kit deals.
Ring Alarm 8-piece kit (2nd Gen) with Indoor Cam: $299.99 $204.98
With this 8-piece Ring Alarm kit that includes monitoring sensors and an Indoor Cam, you can have a great start to a complete home security system.
Ring Alarm 5-piece kit (2nd Gen): $199.99 $129.99
For the home that already has a few cameras and just needs to fill out a system with some sensors and a control hub, this 5-piece kit is perfect.
Ring Alarm 14-piece kit (2nd Gen): $329.99 $209.99
For larger homes or those that want extra control panels, this 14-piece kit will outfit your home nicely. Just don't forget to add a camera if you don't have some already.
Whether you already have some of Ring's best devices, like a Ring Video Doorbell or camera, or are ready to begin your home security journey, adding a central hub and sensors can help bring it all together. That's where a Ring Alarm kit can really help out. These kits come in different configurations to get the one that best fits your needs.
Since Ring's Video Doorbells are some of the most popular devices, many folks already have them. This means that for those individuals, all that's needed to finish securing their home are some sensors, a central hub, and a camera inside the house. For that, the Ring Alarm 8-piece kit (2nd Gen) with Ring Indoor Cam is perfect.
The Ring Base Station includes battery backup, a keypad to arm and disarm the system, contact sensors, a motion sensor, a range extender, and the very helpful Indoor Cam. As for services, you'll have 24/7 monitoring, Alarm Cellular backup, and more.
But what if you already have a few Ring devices and need sensors and a central hub? Well, then the Ring Alarm 5-piece kit will work just great! You get the base station, keypad, contact sensor, motion sensor, and range extender. You'll be able to integrate your existing Ring products into the system and manage everything from one place.
However, if you need more than just a couple of sensors and have a home where you can utilize multiple keypads, this Ring Alarm 14-piece kit is the way to go. It is like the smaller 5-piece kit but with more sensors and a second keypad.
Ring makes some of the best security cameras and integrates all of its products into a cohesive platform that makes managing each piece of the entire system easy. We've put together a helpful guide if you need help deciding which Ring Alarm kit is best for you. There are more bundles available than just these three. So, once you know which Ring Alarm setup will be best for you, if one of the options listed above doesn't match your needs, check out this link to see all the kit deals.
Be an expert in 5 minutes
