How to discover and enable Amazon Alexa's accessibility features
Enabling Amazon Alexa's accessibility features can open up the helpful assistant to more people.
There are many ways in which technology can help people, and one such example is the smart assistant. Amazon Alexa is a great example of what is possible with your voice, such as asking for answers to questions or helping with turning on appliances in the home. Alexa can be particularly useful for those with accessibility hardships like hearing and vision — so long as you enable Amazon Alexa’s accessibility features.
How to let Amazon Alexa be even more helpful
By enabling the various accessibility features for the best Alexa devices, those who need additional assistance will find even more usefulness from the smart speakers. There are options within the Alexa app that can help vision and communication when interacting with the digital assistant.
1. Open the Alexa app on your phone.
2. Tap on More in the lower right corner.
3. Select ⚙️Settings.
4. Choose the Accessibility option
5. Tap on the toggles beside each option you would like to use.
Be an expert in 5 minutes
On the accessibility page, you can tap on Learn More to learn what that feature can do. Another way to learn about the Alexa Accessibility features is to say, “Alexa, tell me about accessibility features.”
Do more with Alexa
Amazon is continuously working to find ways for its smart speakers to help with everyday things along with helping those in need through accessibility features and programs like Alexa Together. While using a smart display like the Amazon Echo Show 8 can provide visual feedback and the ability to type responses, Alexa accessibility features can work well on a smart speaker such as the Echo Dot. These are some of the tools that make Alexa accessible to more people.
The Echo Show 8 is an excellent device for the kitchen counter or bedside table thanks to its 8-inch screen size. It's big enough to help out with recipes, but still small enough not to take up too much space. Turning on accessibility features makes this great smart display even more helpful.
