Best Wi-Fi 6 routers 2025
Looking to switch to speedier Wi-Fi? We've got you covered.
1. At a glance
2. Best overall
3. Best value gaming router
4. Best compact mesh router
5. Best value
6. Best gaming router
7. Best router for large homes
8. Best 5G hotspot
9. Best mesh router
10. Best 10Gig router
11. Best for a lot of devices
12. FAQ
Just about everyone uses Wi-Fi on a daily basis, which is why the best Wi-Fi 6 routers should be easy to set up with little to no downtime. Wi-Fi 6 tech helps us realize multi-gigabit wireless speeds at home, with wide 160MHz channels and tweaks to features like beamforming and MU-MIMO to deal with congestion.
Wi-Fi 6 can also keep up with more devices at once as our data consumption continues to grow. Most manufacturers have also started bundling in powerful software, including parental controls, to make staying in control of your network easier than ever.
Mesh with Wi-Fi 6 makes a lot of sense for people looking for stability and coverage, thanks to its improved handling of multiple connections. Even so, Wi-Fi 6E routers integrate Wi-Fi 6 tech to the 6GHz band, so there's still some room left for more speed if you need it. Some Wi-Fi 6E mesh systems also use 6GHz for faster backhaul speeds, if you're willing to spend a bit more.
Still, for most people Wi-Fi 6 is more than fast enough, with speeds sufficient for multi-gigabit connections. For most folks with an internet connection of 1Gbps or lower, Wi-Fi 6 is the right choice for the time being. So if you're thinking of upgrading your home Wi-Fi and are looking for a powerful Wi-Fi 6 router, read on.
At a glance
Best overall
The RT-AX82U is a balanced Wi-Fi 6 router that has all the features you need. If you need more coverage, you can always turn it into a mesh system with ease.
The GX90 is a tri0band router that combines a striking design with fast connectivity, and a robust feature-set. If you want a gaming router for less, this is the way to go.
If you need a mesh system that doesn't take up too much room, the eero 6+ is the obvious choice. It uses dual-band connectivity and offers plenty of additional features, making it a great choice for most homes.
Best value
The RT-AX1800S doesn't have a lot of extra features, but it delivers reliable Wi-Fi 6 connectivity, and does so for a lot less than its rivals.
Best gaming router
The GT-AX6000 is a gaming router that's designed for multi-gigabit households. It has 2.5GbE WAN and LAN connectivity, terrific bandwidth, and a suite of additional features designed to make the most out of gaming.
The AmpliFi Alien is a standout Wi-Fi 6 router. It has incredible bandwidth, has a unique design with a large screen that showcases real-time stats, and is straightforward to set up and use.
Load the next 4 products ↓
Best 5G hotspot
Want to use a 5G connection as the backbone of your home network? The Nighthawk M6 lets you do just that.
Best mesh router
The ZenWiFi XT8 is a terrific choice if you want a mesh system. It has tri-band connectivity, stellar coverage, and built-in security features that don't cost anything.
Best 10Gig router
Ready to move beyond Gigabit connectivity? You'll want to take a look at what the RT-AX89X has to offer. This router has a 10GbE port that lets you maximize multi-gig connections, and you get a ton of extras.
Say you have a lot of devices that connect to Wi-Fi, and need something that can handle the load. You'll want to get your hands on the Archer AX73.
Best overall
Specifications
Reasons to buy
Reasons to avoid
The ASUS RT-AX82U is a very well-balanced Wi-FI 6 router, with plenty of speed for a family thanks to its AX5400 connection. This speed breaks down to 4804Mbps on the 5GHz band, with another 574Mbps available for 2.4GHz devices. The 5GHz band also supports 160MHz, so even your fastest Wi-Fi 6 devices can connect at full speed.
Around the back, you get four gigabit Ethernet ports for wired devices, including one that is prioritized for gaming. There's a USB 3.2 port so you can easily access a drive from your network. There are four adjustable antennas on the back, allowing you to set this router up for your home, even if you want to mount it.
The front of the router has RGB lighting coming out of the vent that can be controlled through the app. Of course, you can completely disable the lighting if it isn't to your taste. Still, this router looks great next to a gaming PC. It's not just for gamers in appearance, however. A gaming mode can prioritize traffic to keep your ping times low in-game, with enough speed left over to keep the rest of the family happy.
ASUS has also knocked it out of the park with software. AiProtection Pro, powered by Trend Micro, is included for free for the life of the product improving your network security. These settings are all available in the ASUS Router app on Android and iOS. Besides that, you also get advanced parental controls so you can stay in control of how your family uses the internet. Finally, you can expand your coverage with other AiMesh-compatible routers without giving up the control you expect from a standalone router.
Specifications
Reasons to buy
Reasons to avoid
The Archer GX90 from TP-Link is a simple AX6600 tri-band router at its core, with software optimization to make it a great fit for a home that puts gaming first. Not only that, but one of the 5GHz bands can be dedicated to gaming, while another band serves the rest of the fast 5GHz devices. Wi-Fi speeds top out at 4804Mbps on the 5GHz gaming band, 1201Mbps on the remaining 5GHz band, and 574Mbps on the far-reaching 2.4GHz band.
What makes this router great for gamers is the software. A Game Accelerator QoS setting recognizes when a game is running, and makes sure that those packets get through first. This setting can also set aside bandwidth for your console or PC. This setting can be disabled with a button in the TP-Link app when you need your speed back for work or downloads. The 2.5Gbps Ethernet port can also be configured as WAN or LAN, enabling a blazing fast internet connection or LAN device.
The Archer GX90 also passes the parent test, with an affordable price for its speed, easy-to-use parental controls, and HomeCare security software included for free. With HomeCare and parental controls, parents can decide when it's time for homework, and when it's time for lag-free gaming.
Specifications
Reasons to buy
Reasons to avoid
Whether you're a student trying and failing to upload a term paper or a professional struggling to connect to a meeting, flaky Wi-Fi can be infuriating and costly. Luckily, most routers have been moving towards faster speeds while improving the software behind the scenes for a more reliable experience. Eero focused its early efforts not on speed, but on creating a Wi-Fi network that won't let you down when you need it most. The eero 6+ keeps this focus but also upgrades the hardware underneath so you can also use your gigabit speeds.
Eero 6+ comes with a dual-band Wi-Fi 6 connection but unlike the first-generation eero 6, it has 160MHz support at 5GHz which essentially doubles the speed potential for most Wi-Fi devices. While only a handful of high-end devices really support 160MHz, the side-effect of the faster band is a faster mesh link. Eero 6+ in a mesh can link its nodes at twice the speed of eero 6 giving it the headroom to deliver near-gigabit speeds across the mesh, even when there's significant interference in your area, such as you'd find in an apartment building.
While speed is the primary upgrade with the eero 6+, it's backed up by a robust app for setup and management and affordable software packages that offer real value to many people. Eero Plus is a subscription service that comes in at $9.99 per month, with several security enhancements and more advanced parental controls. It also comes with the Encrypt.me VPN service, Malwarebytes, and 1Password to help you practice safer Wi-Fi habits away from your home network.
Best value
4. ASUS RT-AX1800S
Specifications
Reasons to buy
Reasons to avoid
One of the things that really sets ASUS' router offerings apart is the software included for free. In the case of the ASUS RT-AX1800S, you get included ASUS' AiProtection Classic security software, as well as parental controls with support for scheduling. ASUS includes these features for free for the life of the product, and doesn't ask for a monthly or yearly subscription as some other brands do.
This router shares many of its specs and physical design with the more expensive RT-AX55. They both feature AX1800 dual-band wireless with 1,201Mbps possible on the 5GHz band and 574Mbps at 2.4GHz. The AX1800S, however, does not include the AiMesh feature that allows multiple ASUS routers to form a mesh, so you're stuck with the coverage the base router provides. For those in a small house or an apartment, this shouldn't be an issue.
On the back, you get four gigabit Ethernet ports for LAN, so you can keep on using your existing wired devices. There is no USB support on this router, but many people never bother setting up network storage. If you're looking for a fairly basic router with good parental control features and enough speed for just about anything most people do on the web, this is a solid choice.
Best gaming router
Specifications
Reasons to buy
Reasons to avoid
At first glance, the ROG Rapture GT-AX6000 from ASUS seems fairly underwhelming. This router has an eight-stream dual-band connection and a hefty price tag, but as we discovered in our review, this is one of the best-performing Wi-Fi 6 routers on the market. ASUS claims up to an 18% increase in throughput compared to older tech, and this holds up to scrutiny with some of the best 5GHz speeds we've seen on 80MHz devices. ASUS also makes it possible for you to use this extra speed to its fullest, with a 2.5Gbps WAN Ethernet port for incoming connections, and a 2.5Gbps LAN port for a device like a high-end gaming PC or even a dedicated NAS.
This router feels almost tailor-made for streamers, whether they're competitive gamers, speed runners, or Vtubers that like to chat. The 2.5Gbps Ethernet ports mean that streamers can keep their quality setting locked at max while saving VODs to something like an Asustor Lockerstor AS6604T NAS. Streamers are often entertainers first, and ASUS has built the tech they need to confidently build the high-capacity network the profession demands. Of course, all this easily translates to video or photo editors working on large projects.
ASUS' software included AiProtection to help protect your network from online attacks, AiMesh to ensure strong Wi-Fi across your entire home, and VPN Fusion so you can pick which devices use your VPN connection. This is helpful for keeping consoles or gaming PCs on a connection with the lowest possible pings.
Specifications
Reasons to buy
Reasons to avoid
It's easy to get bogged down with spec sheets and product comparison tools when shopping for the best Wi-Fi 6 router, but when it comes down to it, what really matters most is the user experience. Our AmpliFi Alien review found this router to deliver impressive performance across the entire house, with a user interface and features that make it easy to stay in control of your home network. This router is made by Ubiquiti, a networking company that has quickly risen to prominence, with its home solutions that remind us of its high-end experience with routers like the UniFi Dream Machine Pro.
This router does have a couple of drawbacks worth mentioning, such as one of the 5GHz bands being limited to Wi-Fi 5. All in, this router can deliver 1150Mbps at 2.4GHz, 1700Mbps on one 5GHz band, and 4800Mbps on the other. This should prove to be more than enough speed for most home users, but if you're looking for the most speed possible in a router, you'll want to go with an AX11000 router like the next pick on this list.
One of the things that stands out the most about the Alien is its appearance. The monolithic design in matte black absorbs incoming light, making its 4.7-inch display and green underglow all the more vibrant. Speaking of the display, this totally unnecessary feature is a feast for the eyes if you tend to be a bit of a nerd. Sure you don't need it but is it really such a bad thing to inject a bit of fun into the mundane?
Best 5G hotspot
7. Netgear Nighthawk M6 (MR6150)
Specifications
Reasons to buy
Reasons to avoid
The Netgear Nighthawk M6 MR6150 is a high-end Wi-Fi 6 mobile hotspot with support for modern 5G networks. If you live in a mobile home, like an RV or boat, for some or part of the year, it makes sense to get an internet solution that can keep up. The Nighthawk M6 fits the bill for a lot of people thanks to its solid coverage, Ethernet out, and optional 5G antennas. That means that this router can easily switch from a mobile solution to a home solution with the right configuration.
It has an AX3600 Wi-Fi 6 connection with up to 700Mbps at 2.4GHz and 2900Mbps at 5GHz. It has enough capacity for 32 devices so the whole family should be able to stay connected. When set up for home use by removing the battery and powering it from the wall, coverage doubles from 1,000 to 2,000 square feet. If you already have a router at home or just need some more coverage, the Ethernet port on the bottom can supply an internet connection to just about any router or mesh.
When it comes to internet service, the Nighthawk M6 supports LTE CAT19 and 5G with mid-band support. If your connection is strong enough, that means up to 2.5Gbps with carrier aggregation. To help you get as strong a connection as possible, the Nighthawk M6 supports TS-9 external antennas including one sold by Netgear. If you use 5G for your internet, this is about the best you can do, except for one device.
The Netgear Nighthawk M6 Pro is an upgraded model with Wi-Fi 6E, mmWave 5G, and 2.5Gbps Ethernet support. In the U.S., the Pro model is only available from AT&T. For more people, the base Nighthawk M6 has more than enough performance, and outside of the city, you won't be seeing much mmWave coverage anyways.
Best mesh router
8. ASUS ZenWiFi XT8
Specifications
Reasons to buy
Reasons to avoid
ASUS' ZenWiFi series combines an attractive and simple design with ASUS' powerful software, making it easy to build the perfect mesh for your home. The XT8 tri-band AX6600 kit covers up to 5,500 square feet with two nodes and can be paired with other AiMesh compatible routers from ASUS if you need more coverage. This also means you can use one of ASUS' gaming routers in one room, without giving up any Wi-Fi coverage for the rest of the house.
On the node, you get a 2.5Gbps Ethernet port for fast fiber connections and three gigabit ports for devices. With a fast 5GHz backhaul, you can support high internet speeds all over the house for both wired and wireless devices. Furthermore, ASUS includes the AiProtection software of its other routers for free with this kit. These features are nice to have but don't always play nice with some devices. Still, they're nice to have if they work out for you.
The compact nodes are nice to look at and are available in white or black, so the nodes can be placed optimally without interfering too much with your home decor. As we saw in our ZenWiFi ET8 review, these nodes also share the look and most software features with the Wi-Fi 6E variant.
Best 10Gig router
9. ASUS RT-AX89X
Specifications
Reasons to buy
Reasons to avoid
Several internet service providers have already launched internet speeds over 1Gbps with some like AT&T offering 5Gbps fiber in some areas. These providers are also working towards 10Gbps service. While very few people actually need that kind of speed, enthusiasts that want the very best in internet speeds will need a router that can take advantage of those speeds. The ASUS RT-AX89X is one of a handful of consumer routers ready for a 10Gbps connection with plenty of ports to use it.
One of the main complaints we had in our Netgear Orbi RBR860S review was that while it worked with a 10Gbps connection, it struggled to distribute that speed with limited LAN and wireless speeds. The RT-AX89X doesn't have this problem with two 10Gbps ports with one as an RJ45 Ethernet and the other as SFP+. SFP+ is a higher-tech cable solution that can use fiber optic cables to connect to a fast NAS or a 10Gbps wired network. Besides that, you have eight gigabit Ethernet ports and an AX6000 connection with 12 streams and 160MHz support so you can even get speeds in excess of 2Gbps on Wi-Fi.
One of the things that makes the RT-AX89X so versatile is ASUS' software. This router comes with AiMesh support for mesh expansion and AiProtection for improved security. ASUS has also made all of this software free so you don't need to sign up for a monthly subscription to get the most out of it. If you're upgrading to a 10Gbps connection, you have a few options including the ridiculously fast ROG Rapture GT-AXE16000 quad-band router, but if you're looking for an affordable 10Gbps solution with flexible expansion, the RT-AX89X is a great choice.
Specifications
Reasons to buy
Reasons to avoid
The TP-Link Archer AX73 is a fast router with dual-band AX5400 speeds. This breaks down to 4804Mbps at 5GHz and 574Mbps at 2.4GHz. Compared to an AX6000 router, it reduces resource allocation to the aging 2.4GHz bands and focuses on 5GHz delivering top speeds where devices need it most. This helps the Archer AX73 achieve a price that works for most people, without giving up much speed for most connected devices. Still, with reduced 2.4GHz capacity, this won't be the best fit for a home with lots of 2.4GHz smart home devices like security cameras.
Around the back, there are four gigabit LAN Ethernet ports, and on the side is a single USB 3.0 port. This router has a nice design with plenty of ventilation on the top, allowing for completely passive cooling. Removing a fan from the equation is just one less potential point of failure. Link Aggregation is supported between two Ethernet ports as well.
This router comes with TP-Link's HomeShield software. Not to be confused with HomeCare, HomeShield offers many of the same features simplified to fit a subscription model. While the subscription is less than the one provided by Netgear, you might not even need it. Basic content filtering is available for free in parental controls as well as security information. HomeShield is $5.99 per month, or $54.99 per year.
Wi-Fi 6 router FAQ
What are the best Wi-Fi 6 routers?
The ASUS RT-AX82U is an AX5400 dual-band Wi-Fi 6 router that will work for just about any family thanks to its fast speeds, great software, and easy expansion options. This router has plenty of speed to take care of a family's streaming needs, as well as the option to optimize traffic for gaming. You also get free security with AiProtection Pro for the life of the router — unlike other brands that charge a yearly fee.
For a family with gamers, the TP-Link Archer GX90 is a great choice. Tri-band AX6600 connectivity and a dedicated 5GHz band keeps gaming fast, with plenty of capacity left over for streamers and social media enthusiasts. Furthermore, TP-Link has included a special Game Accelerator QoS setting alongside HomeCare security and advanced parental controls.
If you want a simple and powerful mesh system that can eliminate dead zones while delivering gigabit speeds, the eero 6+ is one of your best bets. This is far from the only AX3000 mesh router, but with eero's easy-to-use software and some of the best reliability we've tested, the eero 6+ is an easy pick. Compared to the affordable eero 6, you double your speeds on the 5GHz band, the band most of your devices use, allowing for not only faster speeds with a single router, but when deployed as a mesh as well.
Should you buy a mesh Wi-Fi 6 solution?
The best mesh Wi-Fi systems are a great way to increase coverage, but they offer more than just square footage. Carefully placed mesh nodes can build a strong network even in challenging conditions, such as a home with concrete walls or around an HVAC system that causes interference. For example, a mesh with Wi-Fi 6 can have a stronger connection to each node, with degredation from interference.
Still, many people don't need a mesh system at all, depending on the size of their homes. If you find that a single router just doesn't cut it, a great Wi-Fi 6 mesh routers will be more capable than one based on Wi-Fi 5. Still, starting with a mesh-capable router gives you the option to expand down the road.
Is it worth it to upgrade from a Wi-Fi 5 router?
The best Wi-Fi 5 routers are still reasonably quick with access to reasonably modern features but they simply can't match the performance of Wi-Fi 6. Also known as 802.11ac, Wi-Fi 5 tops out at 867Mbps for most devices and with a little interference, actual speeds are often only around half of that. While speeds on Wi-Fi 5 are still serviceable, the older tech won't hold up as well when more devices start to get online.
If you've noticed that your speeds are inconsistent throughout the day or you have a lot of devices in your home, it is time to look into a Wi-Fi 6 upgrade. That being said, if your Wi-Fi 5 router is still keeping up with your needs, there's no rush to upgrade outside of some newer software features.
Should you care about Wi-Fi 6E?
Wi-Fi 6E uses a 6GHz band in addition to the traditional 2.4GHz and 5GHz. This new band has many more available channels, including seven possible simultaneous 160MHz wide channels. This allows the router to use 160MHz to a much more significant effect, with much less interference than is possible with the single wide channel available at 5GHz.
While this is all very impressive, only a handful of devices currently support Wi-Fi 6E. For most people, there's not much reason to upgrade just yet, and with Wi-Fi 7 debuting shortly, there really isn't much of an incentive to buy into Wi-Fi 6E.
However, some of the best Wi-Fi 6E routers are already available if you want to be ready for the future, and they all work with standard Wi-Fi 6 and Wi-Fi 5 devices.
What about Wi-Fi 7?
Wi-Fi 7 is still being finalized — it'll be ready in 2024 — but that hasn't prevented brands from already rolling out routers based on the new standard. While Wi-Fi 7 doesn't introduce any new bands, it increases the channel width to 320MHz, and offers exciting new features that facilitate multi-gig data transfers easily.
That said, you shouldn't make the switch to Wi-Fi 7 just yet. While the best Android phones include a Wi-Fi 7 modem, the tech is still a year or two away from maturing, and right now, Wi-Fi 7 routers are costly — Netgear's Orbi 970 mesh system is an eye-watering $2,499.
We'd suggest waiting a year or so until affordable Wi-Fi 7 routers start rolling around, which is when an upgrade makes much more sense.
Be an expert in 5 minutes
When Samuel is not writing about networking or 5G at Android Central, he spends most of his time researching computer components and obsessing over what CPU goes into the ultimate Windows 98 computer. It's the Pentium 3.
- Harish JonnalagaddaSenior Editor - Asia
