Android Central Verdict
This affordable tracker thinks outside the box, bringing USB-C charging to Bluetooth trackers for what may be the first time ever. The Pebblebee Clip works on the Google Find My Device network, has a generous Bluetooth range, and rings pretty loud enough. There's no reason not to use this tracker to track your stuff.
Pros
USB-C charging
Google and Apple Find My Device versions available
Clip and keyring hole
IPX6 water resistance
LED lights and loud ringer
Affordably priced
Wide 500ft range
Cons
Can't use Google Find My Device and Pebblebee app together
No dust resistance
With the launch of Google's new Find My Device network, all the best brands rushed to release updated versions of their item trackers. The Pebblebee Clip for Android was Pebblebee's answer to the revamped Find My Device network.
You can grab Pebblebee's Bluetooth trackers that work with the Google Find My Device network in various shapes and sizes. There's card-shaped ones for your wallet and even a slim little oblong one that goes into a pet collar or sticks to remotes.
The Pebblebee Clip for Android is my favorite form factor for various reasons. This Bluetooth tracker comes with a metal keyring out of the box. It's one of those upscale keyrings that have a foldable clasp, not just a regular old spiral-shaped keyring. This makes it super easy to attach it to anything out of the box, no accessories or add-ons required.
The Pebblebee Clip has a big button like any other Bluetooth tracker. Pressing it helps you find your phone. Unlike most trackers, however, it also sports a USB Type-C port for charging and LED lights on the side to indicate charging. Replaceable batteries are great, but I find USB-C charging to be even more eco-friendly as there's less electronic waste being produced in the form of disposable batteries.
The Pebblebee Clip for Android is really small and just nice to attach to common household items such as keys, bags, and pet collars. It's also really lightweight, has a Bluetooth range of 500ft or 152m, and has a robust IPX6 waterproof rating. Unfortunately, there's no dust resistance on this tracker.
Pebblebee makes a separate iOS version of the Clip, so the Pebblebee Clip for Android does not work with iOS devices. You still get notified about unknown Pebblebee Clip for Android units on your iPhone though, as I discovered during my testing.
Setting up the Pebblebee Clip is a breeze. You get to choose between setting it up on the Pebblebee app or the Google Find My Device app, which was am annoying limitation. If you choose the Pebblebee app, you can only use the Pebblebee network to track and locate the Pebblebee Clip.
Tracking aside, features like the melody of the ringer and the ability to find your phone with the Pebblebee Clip are only available through the Pebblebee app. You forgo these options if you set up the tracker on the Google Find My Device app.
Compared to trackers like the Moto Tag, it's much easier to use the Pebblebee Clip out of the box. It is also far simpler to unpair, reset, and repair with other devices. This is because of the button, which presses exactly when you want to and never when you don't.
For the low price of $29.99, anyone can get the Pebblebee Clip for their tracking needs. It rings really loud, with high enough volume levels that I could hear the ringer from the other side of my apartment.
The real draw here is USB-C charging. It carries out the same functions as other Bluetooth trackers, but what really stands out is the Type-C port built into it. Pebblebee even includes a USB-C cable for free, adding more value to the product overall. I only wish it worked with both Google Find My Device and the Pebblebee app simultaneously.
USB-C FTW
The Pebblebee Clip is the ideal tracker for Android users. It works with Google's Find My Device network, withstands water exposure, and has USB Type-C charging, a unique feature that you don't find on most, if any, Bluetooth trackers.
Namerah enjoys geeking out over accessories, gadgets, and all sorts of smart tech. She spends her time guzzling coffee, writing, casual gaming, and cuddling with her furry best friends. Find her on Twitter @NamerahS.
