Best Samsung Galaxy Z Flip 4 chargers 2023
Charge her up at the fastest possible rates.
Samsung's fancy-schmancy Galaxy Z Flip 4 is here in all its flipping and folding, multi-colored glory. While there are no drastic upgrades, the battery and charging front is definitely much better this time around. You can juice up your Z Flip 4's 3,700mAh cell at 25W wired, and 10W wireless charging speeds, with the right charger in hand.
That's where we come in. You don't need to worry about compatibility and all that jazz because we've rounded up the best Samsung Galaxy Z Flip 4 chargers for you right here.
Power up your Samsung Galaxy Z Flip 4
Default choice
Samsung's own 25W Super Fast Charging USB-C Charger is one of the best Type-C chargers for anyone, making it a no-brainer for the cool new flippable Galaxy phone. You easily get the top wired charging rate for the Samsung Galaxy Z Flip 4, and the wall charger on its own is delightfully cheap.
Versatile and speedy
Anker works literal magic into its charging products, and the Anker Nano II 65W is no exception. You'll get the highest charging speed on your Galaxy Z Flip 4 and various other devices, including laptops! It has two Type-C and one USB-A port, Power IQ tech for smart energy management, and prongs that tuck away when you're done charging.
Wireless power
Do away with cables and cords with the minimalist Samsung 15W Wireless Charger Single (2022). This square pad can top up your Samsung Galaxy Z Flip 4 at 10W wirelessly, which is the highest possible output over the air. You do need to connect the wireless charger pad itself with a wall charger that has PD 3.0 and QC 3.0 to squeeze out that 15W speed.
Small but mighty
Voltme's Revo 30W USB-C GaN charger is positively tiny, and it has foldable prongs too, making it incredibly portable. Just like the Anker Nano II, it's made of gallium nitride for better efficiency, and has a designated V-Dynamic chip for smart power management. You get one USB-A and USB-C port each, along with fast charging profiles for the Z Flip 4, iPhones, Pixels, and more.
Purple flurple
The 30W Anker 511 (Nano 3) Charger is nearly as small as the AOHI Magcube. It one-ups the competition by retaining the fast 25W charging speed for the Z Flip 4 and bringing folding prongs to the table. If you're a fan of colors, Anker has the most colorful array of shades any charger brand has ever made.
Convenience in your pocket
The Mophie Snap+ Juice Pack Mini sports a decent 5,000 milli amps within, ready to charge your Z Flip 4 a little more than once on the go at 7.5W wirelessly. Just like your baby foldable, the Snap+ Juice Pack Mini has a small footprint. Interestingly, it also comes with a small magnetic ring that can be attached to your phone using an adhesive. Once on, you just plop the little wireless portable charger on to your Z Flip 4 magnetically.
Larger charger
If you need more than 5,000mAh in a portable form factor, the Samsung Super Fast 25W Portable Wireless Charger is the better option. You get a higher 10,000mAh capacity, although it is much larger is size. Not only do you get 10W charging wirelessly, but the Samsung battery pack can also juice up your Z Flip 4 at the max 25W wired fast charging speed.
Travel-friendly option
Charge your Z Flip 4 at 25W in your car with the OtterBox USB-C Dual Port Car Charger. Both ports deliver a combined power of 50W, with the bottom port getting 30W and the upper one receiving 20W when in use.
Positively tiny
Believe it or not, this teensy little wall charger can juice up your Flip 4 at 25W without breaking a sweat. I have personally used this tiny AOHI Magcube USB-C charger and its size is simply astonishing when held in hand. There's even an LED indicator that changes colors when charging your flip phone.
Juice up your Samsung Galaxy Z Flip 4 with these solutions
You may or may not have noticed that many of the best Samsung Galaxy Z Flip 4 chargers overlap with the best Galaxy Z Fold 4 chargers. This is because the smaller Samsung foldable touts the same 25W charging speed. The Z Flip 4 also requires the same Super Fast Charging specification to receive that fast 25W power output.
Unlike the Z Fold 4, the Z Flip 4 supports slower 10W wireless charging. However, you still need Samsung's propriety Fast Wireless Charging feature in your charger of choice. To add to that, the wireless charger also needs to be hooked up to the right wall charger that has PD 3.0 and QC 3.0.
The quickest and cheapest charging solution for the Samsung Galaxy Z Flip 4 is available in many forms. Samsung's old but reliable 25W USB-C brick is affordable and an excellent choice by default. If you want to get more use out of your Z Flip 4 charger though, consider upgrading to a multi-port GaN charger from Anker or Voltme instead.
Wireless charging is convenient enough, but even more so when incorporated into a portable battery pack. Meet the modest Mophie Snap+ Juice Pack Mini. I have used plenty of Mophie's wireless charging products and vouch for them based on my hands-on experience. The adorable 5,000mAh Snap+ Juice Pack Mini fits comfortably in pockets and small compartments. In a stroke of genius, Mophie also gives you a magnetic ring that has a strong adhesive to stick it onto your Z Flip 4. This attracts the little wireless battery pack and holds it securely in place while charging.
Be an expert in 5 minutes
Namerah enjoys geeking out over accessories, gadgets, and all sorts of smart tech. She spends her time guzzling coffee, writing, casual gaming, and cuddling with her furry best friends. Find her on Twitter @NamerahS.
