Best Samsung Galaxy Watch 5 and 5 Pro bands 2025
Express yourself with these amazing Galaxy Watch 5 and Watch 5 Pro bands.
Samsung may have rolled out the Galaxy Watch 6 series already, but the first-party Samsung Galaxy Watch 5 and 5 Pro bands are still worth considering. If you want multiple bands that go with various occasions, get a mix of versatile bands from third-party vendors. There's a lot on the market, suitable for every budget.
We've rounded up some of the best Samsung Galaxy Watch 5 and 5 Pro bands to help you personalize your Wear OS device with flair. These bands cater to diverse tastes and fit many occasions, whether you're headed to a black tie event or the gym. Oh, and the best part is, you can use your Galaxy Watch 5 and its Pro's 20mm quick-release bands on the new-gen Watch 6 and last-gen Watch 4 as well.
These Galaxy Watch 5 and 5 Pro bands are a sight for sore eyes
Best overall
It doesn't get classier than this stainless steel strap from Spigen. Available in three shades, this 20mm strap has a mesmerizing matte finish and matching metal clasps. Grab one in black, silver, or rose gold, and easily swap out your pre-existing straps in a jiffy thanks to the quick-release pin system. To make a good band even better, the Spigen Galaxy Watch Band Modern Fit is really affordable, too.
Best for women
TRA's 5-packs of Watch 5 and Watch 5 Pro bands come in sets of assorted shades, making it a fantastic deal for under $10. You can choose the right mix of colors to match your personal taste or preferences. The woven design of these silicone bands is breathable, making them especially comfy for rigorous activities. Plus, they look stylish, too.
Best value band
For under $10, you get a solid silicone band replacement with a push button hidden clasp and compatibility with a wide range of Galaxy smartwatches. Available in 20 solid color options, you can personalize the look, even pick up a couple of these to match different outfits or activities. Think Pine Green when you're running on the trails and Midnight Purple for the office.
Best Samsung branded band
If you want to stick with the Samsung brand, the Hybrid Band is a good option that combines both silicone and leather. Yes, it will cost significantly more than the others. But you can be assured the quality and fit will be perfect. You'll have to stick with black, but it's a solid and versatile band you can wear just about anywhere.
Best elastic band
Don't want to have to deal with buckles at all? With this ultra-stylish band, perfect for a teen or tween (or someone with a more playful sense of style), you can slide the watch easily on and off your wrist. With tons of positive reviews, this elastic band is recommended for wrists that are from 5.5 to 6.9 inches in diameter, so make sure to measure first. If it fits (literally), you'll love how easy this is to put on and take off. Plus, you can choose from dozens of colors.
Best stylish metal band
The WINGLE Galaxy Watch 5 Metal Band is an elegant creation with uniquely-shaped metal links and a slim band that isn't too wide. Everything about this band screams fancy, from the titanium and silver finishes to the luxurious metal clasps. It's not as affordable as the silicone multipacks, but the quality is worth it.
Best sporty band
DaQin's six-pack offers you a set of breathable, soft, and super comfy silicone bands. This is a good choice if you like to work out with your Watch 5 or 5 Pro on, since sweat and heat will dissipate faster. Grab this ultra-affordable multipack in a bunch of different color combos and two sizes, large and small, for less than two tenners.
Best dressy band
OTOPO's stainless steel Galaxy Watch 5 Metal Mesh Band is held in place using a magnetic clasp. The metallic mesh look pairs well with the four lovely shades available. If you're a fan of the Bora Purple colorway of the Watch 5, the colorful strap with a silvery lavender finish will please you to no end. Not to mention, it costs half the price of what Spigen has to offer.
Best casual, everyday band
Variety is the spice of life they say, and they aren't wrong. This six-pack of Charlam Stretchy Nylon Watch Bands come in a fun mix of solids and patterns. You can easily adjust the fit and the sturdy nylon material is very durable. This set of Samsung Galaxy Watch 5 straps is a great buy for everyday use and it doesn't break the bank.
Best wide and thick band
BARTON's rugged Canvas Quick Release Watch Band is built to endure. This chunky Galaxy Watch 5 and 5 Pro band can withstand quite a lot of wear and tear. You get to choose from over two dozen colorways and also pick different colored metal buckles to go with those shades. The Crimson Red looks particularly handsome, with a Silver, Black, or Gunmetal Grey to go with it. The 20mm quick-release band is compatible with plenty of older Galaxy smartwatches as well.
Best simple band replacement
Looking for a value pack that matches your entire closet? HSWAI's 20mm Soft Silicone Strap for the Galaxy Watch 5 and 5 Pro comes in a mix of 10 bright shades. That's right, 10 options! That's less than $2 per band if you do the math. You can choose from two sets of assorted hues, depending on the most common colors in your wardrobe.
Best bracelet band
This boho leather band from WONMILLE is compatible with the Watch 5 and 4 series and there are 13 lovely shades available. There are several different leather colors and metal bracelets mixed together with sturdy metal clasps. You can choose any combo that tickles your fancy as they all look great. This band has glowing reviews and it fits tight budgets.
Best rugged band
You might not like the price tag, but Ritche is a reputable brand that manufactures high-end accessories. The 20mm Classic Silicone Watch Bands from Ritche come in many color combinations. The unique geometric pattern and contrasting dual tones elevate this Samsung Galaxy Watch 5 and Watch 5 Pro band. And don't forget, this band still costs less than a third of Samsung's own bands.
Best leather band
Some leather straps might look clunky on smaller wrists. Fear not, my small-handed brethren, for the GEAK 20mm Slim Leather Watch Band is here to save the day. This option is slimmer, but it still fits your Galaxy Watch 5 and 5 Pro nicely. You get a couple of colorways, but your choices aren't as extensive as with other brands.
Best ultra-slim band
EnoYoo's 10-pack doesn't tout much variety in terms of colors but you do get extremely narrow silicone bands. Available in small and large sizes, these slim silicone bands are suitable for tiny wrists. They're also perfect if you want to layer your Galaxy Watch 5 or Watch 5 Pro with other bracelets and beads.
A galaxy of compatible bands to choose from
Just like the Galaxy Watch 6, the Samsung Galaxy Watch 5 and 5 Pro have the same quick-release system for swapping out watch bands that we saw on the Galaxy Watch 4 and the Watch Active 2. This means that you can still use your older 20mm bands if you want. Having the same band mechanism also means you don't need to learn how to swap bands on your newer Samsung Galaxy Watch, as it's the same process that you'd follow on the Watch 4 series.
Those of you who'd still like to grab one or two new watch bands for your Galaxy Watch 5 or 5 Pro are in luck. Not only do you get to choose from the newer bands made for the Watch 5 series, but you also get to have your pick from the best Galaxy Watch 6 bands and Galaxy Watch 4 bands.
The best Samsung Galaxy Watch 5 and 5 Pro band is the spectacular Spigen Galaxy Watch Band Modern Fit (20mm). Spigen is a name that one can trust blindly, as the brand doesn't compromise quality. The 20mm metal band fits your Galaxy Watch 5 and Watch 5 Pro, as well as select older Galaxy Watches. Available in three colors, the Spigen Modern Fit sports an extremely versatile design that can be paired with a multitude of outfits. It has a high-end finish, and the metal clasps are sturdy, making this band worth every dime.
DaQin's Galaxy Watch 20mm Silicone Sport Bands multipack is better suited for an active lifestyle. It also helps that this is a six-pack, adding phenomenal value. For our leather lovers, Ritche's gorgeous Quick Release Leather Watch Band (20mm) is a match made in heaven. You get a genuine leather band that has been crafted with care and precision, with a wide assortment of colors from which to choose. It's not as good of a deal as many of the multipacks on this list, but the high-quality leather is superb.
Be an expert in 5 minutes
Namerah enjoys geeking out over accessories, gadgets, and all sorts of smart tech. She spends her time guzzling coffee, writing, casual gaming, and cuddling with her furry best friends. Find her on Twitter @NamerahS.
- Roydon CerejoContributor
