Best Pixel 7 Pro screen protectors 2025
The best Pixel 7 Pro screen protectors give you the protection your phone needs.
There are different types of screen protectors on the market. Self-healing screen protectors automatically remove scratches, and privacy screen protectors prevent those with spying eyes from seeing what's on your display. Military-grade protectors, made from a resilient film first used to protect U.S. military helicopter blades, give you that extra layer of protection. The one you choose will depend on your preferences.
The Pixel 8 Pro took the spotlight away from the Pixel 7 Pro, but that doesn't mean it's not worth protecting. It'll flaunt its 6.7-inch LTPO AMOLED panel with a 120Hz refresh rate. The display is made of glass, so it will need one of the best Pixel 7 Pro protectors to keep it in tip-top condition. With our top picks, you can choose from tempered glass to military-grade protection, but what matters is that you are happy with your choice and get the protection your phone needs. Let's take a look at the best Pixel 7 Pro screen protectors.
These are the best Google Pixel 7 Pro screen protectors
Staff pick
The LK 2 pack for Google Pixel 7 Pro will keep your screen in good condition thanks to the self-healing TPU film. Its hassle-free installation keeps things simple and won't affect your phone's zoom-in function, so you can continue to take perfect pictures.
Self-healing properties
TOCOL's film-based screen protector uses a flexible, high-grade TPU material whose self-healing technology makes small scuffs and scratches disappear on their own with time. It maintains up to 99.9 percent screen clarity and doesn't affect the Pixel 7 Pro's touch response either. The package comes with two protective films for the screen, as well as two glass protectors for the rear camera visor.
For that perfect fit
Whitestone Dome Glass has some of the best screen protectors out there, and their Pixel 7 Pro offering is no different. With its liquid dispersion technology, the screen protector evenly covers the entirety of the display and hardens to create an anti-scratch barrier. Sure, it's a little expensive, but the flawless fit and finish justify the high price. Oh, and there's also a UV curing light and camera module protector included in the package.
Thin yet tough
If you're not a fan of thick tempered glass screen protectors, we suggest taking a look at Milomdoi's film-based option that uses TPU material. It provides full coverage at the edges of the Pixel 7 Pro's display, and small scratches go away on their own with time. The screen protector works well with the majority of cases and doesn't interfere. All the necessary installation tools are in the box.
For your eyes only
The CWQZGUF privacy screen protector is a tempered film that limits the viewing angle of your phone's screen. This makes it difficult or impossible to see what's on your screen from the side. If you want to use your phone on the bus or train without others following along, a privacy screen protector is a must. This pack even comes with two tempered glass camera lens protectors.
Military-grade protection
If you're looking for a tough and reliable Pixel 7 Pro screen protector, look no further than the MilitaryShield from Armor Suit. Laser-cut in the U.S., it utilizes an optically clear material that's tough and doesn't discolor over time. The screen protector provides full coverage and features self-healing technology to repair minor scuffs on their own. Oh, and it's backed by a lifetime replacement warranty as well.
The Pixel 7 Pro's big screen deserves the best protection
Undoubtedly, the Google Pixel 7 Pro is one of the best Android phones you can buy. This is packed with goodness, from a stock Android experience to class-leading imaging chops to AI features. As one would expect from a device this amazing, it features a 6.7-inch LTPO AMOLED panel that's a joy to look at and interact with, all thanks to its 120Hz refresh rate. But if you want that screen always to look as great as it does when you take the phone out of its box, you should consider getting one of these best Google Pixel 7 Pro screen protectors.
Our top vote goes to the LK 2 pack for the Google Pixel 7 Pro screen protector, which provides full edge-to-edge coverage and comes with everything you need, including self-healing TPU film. If you don't want others peeking at your phone while using it publicly, we suggest the CWQZGUF privacy screen protector. This screen protector allows the contents to be visible only to the person directly in front of the display. It won't even look like your phone is on to everyone else.
On the other hand, Milmodoi's flexible screen protector is the perfect option if you dislike thick tempered glass screen protectors. It uses a thin, tough TPU material with self-healing properties.
A screen protector is essential, but it can't keep the whole body of your phone safe from damage, so make sure you check out some of the best Pixel 7 Pro cases as well.
When Rajat got his first Personal Computer—a Pentium III machine with 128MB of RAM and a 56kbps dial-up modem—back in 2001, he had little idea it would mark the beginning of a lifelong love affair with gadgets. That fascination, combined with a penchant for writing and editing, ultimately led to him becoming a technology journalist. Some of his other interests include Photography, Hand Lettering, and Digital Typography. Rajat is also somewhat obsessed with wrist-worn timepieces and appreciates a Casio just as much as a Jaeger-LeCoultre.
