Best Pixel 7 and 7 Pro chargers 2025
Gotta charge 'em up.
When you get one of the best Pixel 7 and 7 Pro chargers, you assure yourself of the maximum charging speed. The charging speed is important, but so is the charger's size. The following chargers meet the different things you're looking for in a charger to find the one that is right for you. You'll find one that gives you that retro look and others that give you the speed and design you're looking for. Are you also looking for a stand-like charger? We've got you covered.
Fastest Pixel 7 and 7 Pro chargers
Staff Pick
Google's own 30W USB-C Charger is reasonably priced and equipped with all you need to charge your Pixel 7 and 7 Pro. There's only one Type-C port here, but the price is decent even if you choose to get the bundle with the USB-C cable.
Max potential
Your Pixel 7 or 7 Pro won't charge at its top wireless charging speed with any other stand save for the Google Pixel Stand (2nd Gen). We wish it had space for a secondary accessory, but it is what it is.
Budget buster
Baseus continues to impress us with its value-packed 30W Dual Port USB-C Wall Charger. This compact USB-C charger sports two ports: one Type-C and one Type-A. The prongs fold away to reduce the charger's footprint even further.
Charging for all your tech
With so much of our tech switching over to USB-C for power delivery, you can eliminate the bulk when you travel by switching to a single charger that can handle all of your devices, like a laptop or tablet. This 100W charger can deliver full-speed charging to your Pixel 7 on the top two ports, even with all other ports active.
Go long
This PowerCombo 100W USB-C Charging Station combines the functionality of your average run-of-the-mill USB-C charger with a lengthy power strip. At the end of the 4.95ft extension cord, you will find two Type-C ports in addition to two USB-A ports and two AC outlets.
Compact and unique
This Gravastar DELTA35 GaN Fast Charger Block is shaped like an old robot. Its arms can be moved around to express your mood, and it has dual USB C ports to charge more than one device. With this little guy, you'll get 35W fast charging with some style on the side.
Made for Google
iOttie and all other third-party wireless chargers cannot deliver the max wireless charging speeds supported by your Pixel 7 or 7 Pro. Still, this 10W stand is a good option since you get a secondary 5W pad on the side to wirelessly charge another device like the Pixel Buds Pro.
Colorful palette
Anker's delightful little 511 (Nano 3) GaN charger comes with folding prongs and you can choose from five beautiful shades. This Type-C brick charges your Pixel at 30W, doesn't cost much, and is unbelievably small in nature.
Made to last
The Anker Nano II 3OW Fast Charger has a downsized design, 59% smaller than an original 30W USB-C charger. This charger gives you Gan Li Technology with a 20% increase in operating frequency. It gives you the power you need to keep your Pixel going.
Comes with an LCD display
Anker's Power Bank IQ 3.0 Portable Charger is a wonderful charging solution for your Google Pixel 7 and 7 Pro. Not only does it have two ports, but it also doubles as a 10,000mAh USB-C power bank when unplugged. Fast and portable? Yes, please!
Comes with a cable
The VOLTME Revo 65 Evo is a thin charger with up to 65W power delivery. It's thin at 14.8mm, making it perfect for hard-to-reach places or sliding into a backpack pocket before heading out. It also has a USB-C cable in the box.
For your car
This dual-port Looptimo 30W Fast USB-C Car Charger has a USB-C port and a USB-A port for versatility. Looptimo's car charger supports both Power Delivery and Quick Charge 3.0 so it can top up your Pixel 7 in a speedy fashion. You get a 3.3ft Type-C cable along with the charger itself.
Lightning strikes with the right charger
Both Google Pixel 7 series phones support 30W wired charging. However, their wireless charging specs are slightly different — 20W for the Pixel 7 and 23W for the Pixel 7 Pro. If you want to harness the fastest charging speed on your Pixel, the charger must have the necessary power output or higher and the PPS fast charging profile. The Extended Power Profile (EPP) is a prerequisite for maximum wireless charging speed when you're topping up wirelessly.
Google's 30W brick is a good, safe choice for most people. The Google 30W USB-C Charger can top up your Pixel 7 and 7 Pro at the highest compatible wired charging speeds. Sometimes, it also comes bundled with a Type-C cord, adding value.
If you prefer to use the same charger for all your gadgets and electronics, especially laptops, choose the UGREEN Nexode 4 100W charger. It is a great choice, with plenty of power to charge all your devices simultaneously.
For something on the go, consider your most common mode of transport. Those who prefer to drive will benefit from the Looptimo 30W Fast USB-C Car Charger. On the other hand, the Anker Power IQ 3.0 Portable Charger is a better fit for public transport users with its built-in battery. It even supports 30W fast charging on battery, so your Pixel will have plenty of power when you get to your stop.
Hopefully, you've found the best Pixel 7 or 7 Pro charger. But remember to get a USB-C cable to go along with it. The nylon-braided cords are better because they are strong and are made to last. If the cable is at a reasonable price, why not grab two?
Namerah enjoys geeking out over accessories, gadgets, and all sorts of smart tech. She spends her time guzzling coffee, writing, casual gaming, and cuddling with her furry best friends. Find her on Twitter @NamerahS.
