Best Nothing Phone (2) cases 2025
Get a solid case that doesn't hide the Nothing Phone (2)'s striking back.
The Nothing Phone (2) tells a compelling story, full of charm and intrigue. This unusual phone comes with an all-glass back with curved edges, and mesmerizing lights that make up the Glyph Interface. Nothing went all out with the specs and succeeded the Phone (1) properly.
Anyone rocking the Phone (2) definitely wants to admire its transparent back and bold look. This doesn't mean that your device has to stay naked though. The best Nothing Phone (2) cases are shock resistant and also allow the phone's design to shine. Here are all our top picks.
Encase your Phone (2) in these clever cases
Best overall
TUDIA makes two cases for the Nothing Phone (2), and they're both equally impressive. The TUDIA SKN is one of the few Phone (2) cases that comes in punchy colors, plus it is semi-transparent, has reinforced edges, and cutouts on the back for the LEDs. Factor in the price and this is the ideal case for anyone.
Best durable case
Ringke ported the Fusion-X over to the Nothing Phone (2) and we couldn't be more excited. The Fusion-X comes in a shadowy gray or fully clear variant. The frame and corners are heavily reinforced, you get lanyard holes on the side, and the port openings and buttons fit nicely.
Best branded case
You can't ever go wrong with a case from Spigen, and this one fits the Nothing Phone (2) like a glove. Available in two colors, it's made with a TPY bumper and a durable PC back. The clear design lets the beauty of the phone itself shine through while still offering great protection, a raised bezel, and large button cut-outs.
Best transparent case
Don't underestimate the transparent Foluu Clear Case for the Nothing Phone (2). This soft TPU cover has reinforced corners so it can sustain drops and impacts. The flexible TPU material is also scratch-resistant and has precise cutouts for all the ports and buttons.
Best with built-in screen protector
The QUIETIP Case for the Nothing Phone 2 has a completely clear back and comes with a built-in screen protector that seals shut magnetically. You can choose from two colors for the metallic bumper frame. This case is both protective and attractive, but it is a little pricey.
Most affordable case
Osophter's transparent cases are excellent and we almost always recommend them for every flagship. The Osophter Nothing Phone 2 Case isn't any different, giving you a basic clear cover at a great price. This option has thick reinforced corners too, plus it has raised edges for extra drop protection.
Best slim case
The Hensinple Nothing Phone 2 Case is made of a hybrid TPU material and has a hard back for extra durability. It repels fingerprints and scratches and doesn't yellow as much over time. You get a Tempered Glass Screen Protector for the Phone (2) and phone strap holes in the case.
Best flexible case
Cresee's Case for the Nothing Phone (2) offers a snug fit, raised bezels around the camera unit for impact proofing, and reinforced corners. This is a soft case that's bendy and has designated holes for a phone strap attachment.
Best rubber case
Suttkue's Nothing Phone (2) Case is made of scratch-resistant rubber. Even though the entire phone cover is transparent, it's designed to repel fingerprint traces and smudges. It has raised edges and reinforced edges to endure shocks and bumps.
The best Nothing Phone (2) cases are durable and good-looking
It is crucial to keep the Nothing Phone (2)'s glass back and 6.7-inch 120Hz OLED panel in mint condition. You don't want your Nothing device to look shoddy at any point. Just like the best cases for the Nothing phone (1), the best Nothing Phone (2) cases preserve your flashy phone and show it off for the world to see. Budget isn't a problem here because most of these excellent phone covers are priced below $10, with one or two odd exceptions.
The TUDIA SKN for the Nothing Phone (2) is unlike any other case for the device, but it doesn't cost anywhere near as much as premium brands would charge for something similar. The TUDIA SKN comes in four shades, has slits on the back for the rear LEDs, and has reinforced corners for better shock absorption. Also, the sides are scored for added grip.
The Foluu Clear Case for Nothing Phone (2) is scratch-proof, has sports reinforced corners, and incorporates designated holes on the side to accommodate lanyards and phone straps. Another big plus is its super cheap asking price.
If you want something that moves beyond the generic soft clear case aesthetic, you'll need to spend a little more. The QUIETIP Case for Nothing Phone 2 is see-through on the back, so you can make full use of the Glyph Interface, but it also has a really cool metal frame. The bumper frame is for more than just looks, absorbing shock when needed. Then there's the built-in screen guard that seals shut magnetically, eliminating the need to grab a separate Nothing Phone (2) screen protector.
Be an expert in 5 minutes
Namerah enjoys geeking out over accessories, gadgets, and all sorts of smart tech. She spends her time guzzling coffee, writing, casual gaming, and cuddling with her furry best friends. Find her on Twitter @NamerahS.
