Best Galaxy S24 Ultra cases 2025
A fine looking case can go a long way.
As the latest and greatest phone in the Samsung line, the Galaxy S24 Ultra isn't a massive leap in feature set from the S23 Ultra. However, it does employ a different exterior design, which means you can't use your old S23 Ultra case on it. The display doesn't have as prominent a curvature, for example, while the edges are slightly different.
Thankfully, there's a whole selection of new fitted cases for the Galaxy S24 Ultra, some which are admittedly expensive, but others that are super affordable. As always, there's a great variety of cases available, so let's dive in.
Feast your eyes on these glorious Galaxy S24 Ultra cases
Best overall
Razor-thin and rock-hard, the Thinborne Samsung Galaxy S24 Ultra Case is made of a strong 600D aramid fiber material. It barely adds any weight or bulk to the S24 Ultra but goes a long way in terms of drop protection. Plus, there's a magnetic ring baked into it that works with the S Pen.
Best patterned case
Spigen's Cryo Armor is properly durable. The same case helped an iPhone survive a fall from an airplane, so surely your S24 Ultra is going to be very safe inside it. Not to mention, the unique pattern doesn't just look cool, it's designed to create a literal cooling effect as well.
Best designed case
BURGA's Samsung Galaxy S24 Ultra Tough Case has a soft interior and a hard shell exterior. The camera and display are cocooned by raised bezels. This low profile hard case provides decent shock absorption and comes in over 200 stunning designs. Think everything from leopard print to floral, plaid, and marble.
Most stylish case
i-Blason reinvented its popular Cosmo Mag series for the Samsung Galaxy S24 Ultra and we are in love. There are seven designs available, a mix of old and new, and the case now has MagSafe support. You get a screen protector and a kickstand built into this drop proof cover as well.
Best grippy case
Dbrand's new MagSafe Grip cases are very cool, but you can't use them with the S24 Ultra because the S Pen malfunctions. Thankfully, you can buy this non-magnetic Grip Case with the same levels of drop protection instead. it comes in so many fun styles, too, including the one depicted here called Glitch Camo.
Best value case
Complement your Titanium S24 Ultra with the Caseology Nano Pop in either BlueBerry Navy or Black Sesame. This dual-toned sleek case comes with raised edges all around, including for the camera lenses, and military-grade impact resistance. It's impressively cheap for the quality and ultra-slim, too.
Best premium case
CASETiFY's thin Impact Case for the Galaxy S24 Ultra has a reinforced frame for better shock resistance. You can grab this robust eco-friendly case in hundreds of transparent, semi-transparent, and opaque designs. These cases are known for a great fit and reliability: they're worth the extra bucks.
Best rugged case
UAG's redesigned Pathfinder Pro Magnetic series is a good look on the Samsung Galaxy S24 Ultra. This military-grade rugged case has MagSafe support built-in and comes in a bunch of mean looking colors. Those who work outdoors, travel, or have slippery fingers will want to invest in this one.
Best kickstand case
The Poetic Neon Magnetic Ring series brings MagSafe compatibility and a kickstand to the Galaxy S24 Ultra. Enjoy using your shockproof case with magnetic accessories and wireless chargers worry-free. The kickstand and finger grip in one is a serious game-changer.
Best branded case
When it comes to branding, Otterbox is right up there for phone cases, known for its reliability, durability, and slim design. The Commuter case has been made for just about every top device on the planet, and yes, there's one for the Galaxy S24 Ultra, too. In four colors, it's slim, durable, military drop tested, and even made from 35% recycled plastic.
Best waterproof case
Sure, the Samsung Galaxy S24 Ultra has an IP68 water-resistant rating, but a little extra protection never hurt, especially if you want to take it underwater in the pool to snap some shots. This case comes with a built-in camera and screen protector and covers the entire perimeter of the phone so you get fully submergible protection. It's a bonus for the beach to keep sand out of its crevices, too.
Best wallet case
This unique case is like a wallet and phone case in one. The PU leather wallet on the back flips open like an actual wallet to reveal cards and cash, then secures closed via magnets. It even doubles as a kickstand. You can't use other MagSafe accessories or wireless chargers, and it adds bulk to the bottom. But it's a trade-off you might be willing to make for the convenience.
Get the best Galaxy S24 Ultra case for your needs
In a galaxy full of outstanding accessories, the Thinborne Samsung Galaxy S24 Ultra Case stands out as the best phone cover. It may feel a little expensive, but the high-quality materials used to make it justify the price. Thinborne promises reliable durability in a lightweight form factor. There's a magnetic ring built right into the case so it's compatible with MagSafe accessories and you get a free screen protector for the S24 Ultra. Plus, this is one of the few S24 Ultra cases that doesn't interfere with the functionality of the S Pen.
Spigen's Cryo Armor is one of the most robust cases available for the Galaxy S24 Ultra. This thing can even survive drops from flying airplanes that are 16,000 feet high! The military-grade drop protection paired with the cooling design and attractive appearance already make this a fine option. Then there's the price tag, which is somehow less than $30, making this the best Galaxy S24 Ultra case on a tight budget.
As more and more excellent Galaxy S24 Ultra cases come out, we'll continue to add all the best ones to this buying guide.
Be an expert in 5 minutes
Namerah enjoys geeking out over accessories, gadgets, and all sorts of smart tech. She spends her time guzzling coffee, writing, casual gaming, and cuddling with her furry best friends. Find her on Twitter @NamerahS.
