Best cases for the Nothing phone (1) in 2025
Wrap it up before it cracks!
The splendid Nothing phone (1) made its debut with a bang because it was so unique and innovative. The device is a little old now, but if you're still holding on to it, get one of the best cases to freshen it up. The Nothing phone (1) has a unique transparent glass back that's more likely to crack or shatter that upon unprecedented impact. Nothing is indestructible, not even Gorilla Glass 5.
Since the Nothing phone (1) has such an interesting backside, you'll want a clear or sheer case for the device. Grab a bumper cover or something transparent to allow the lights to shine through while protecting your fragile Nothing phone (1).
Marvelous cases for your Nothing phone (1)
Colors: Frosted Blue, Frosted Black, Frosted Clear, Frosted Green
TUDIA is an underdog brand that doesn't get enough recognition, and this cleverly engineered SKN Rugged Fit Case for the Nothing phone (1) is proof enough. The Glyph lights peek through, the back is sheer, the sides are grippy, and the corners are reinforced for drop protection. You get to pick from four lovely frosted hues.
Colors: Smoke Black, Clear
The Ringke Fusion-X for the Nothing Phone (1) comes with a robust and stylish bumper frame and the brand's propriety Duo-QuikCatch lanyard holes on both sides to attach a strap. The corners are reinforced to resist impact from shocks and bumps.
Colors: Space Crystal
Spigen's sleek bumper case is sleek enough to allow wireless charging with ease but it also bolsters drop protection thanks to the sturdy frame. The Spigen Ultra Hybrid Case exposes your Nothing phone (1)'s back with a safe, transparent layer encasing it for safety.
Colors: Aramid Fiber
It's pricey, but this is the most rugged protection you're going to find for your Nothing phone (1). The Thinborne Aramid Fiber Nothing Phone 1 Case is made of highly durable and tough aramid fiber material. There are cutouts on the back so that the LED lights are visible and a cool carbon fiber texture for aesthetics.
Colors: 20 light and dark colors
kwmobile's offering is a simple see-through soft case. It comes in 20 diverse shades and you get a lovely matte finish. Although this cover isn't very protective, its snug fit and the sheer number of colors available make it one of the best cases for the Nothing phone (1). From bright yellow to dark maroon, and deep teal to light lavender, there's every hue imaginable.
Colors: Clear
Osophter creates affordable clear cases for all the best Android phones. The case maker's offering for the Nothing phone (1) features raised bezels all around, a see-through rear panel, and a handy rotating ring grip that doubles as a kickstand in a pinch. It comes with a free glass screen protector.
Colors: Black, Gray
The Eastcoo Protective Case for Nothing Phone 1 has it all: thickly raised lips all around, precise cutouts, wireless charging support, and a clear back to show off that Glyph Interface. Your Nothing phone (1) will stay nice and safe inside this impact-resistant clear cover.
Colors: Black, Black/Blue, Black/Red, Black/Silver, Blue, Pink, Red
Full back coverage is hard to find but the COTDINFOR Nothing Phone 1 Case makes it possible. This matte hardshell case has slits for the Glyph Interface but covers up the rest of your Nothing phone (1) nicely.
Colors: Red, Blue, Black, Green
Guzhthi brings a splash of red-hot color to your Nothing phone (1). There are other color options, but the red shade is truly eye-catching. In addition to its bold, see-through look, the Guzhthi Nothing Phone 1 Case brings you heavy-duty shockproofing owing to its protruding edges. You also get a tempered glass screen guard.
Less is more when it comes to the best Nothing phone (1) covers
The best cases for the Nothing phone (1) are obviously transparent or semi-transparent options with bolstered drop protection. You don't want to cover up the main attraction of the device: those LED lights embedded into the back that make up the Glyph Interface. Since everything on the rear is encased in glass, shock resistance is your number one priority when getting a cover for your Nothing phone (1). This should be followed by a sturdy screen protector.
Although your options are pretty limited options, the best Nothing phone (1) cases don't deprive you of excellence. Our favorite phone (1) cover of the lot is the TUDIA SKN Rugged Fit Case. You get a clear case with raised edges and reinforced corners, adding much-needed protection from all manner of bumps, drops, falls, and shocks. The sheer back allows you to make use of the Glyph Interface without interruption, while also letting you admire the unusual transparent nature of the phone. Meanwhile, the sides are cleverly textured to add grip as yet another anti-fall measure.
For absolute coverage, both the Ringke Fusion-X as well as the Spigen Ultra Hybrid bumper cases achieve the same level of drop protection. Although you don't get as much variety when it comes to the color selection, the drop protection is top-notch on both of these fantastic Nothing phone (1) cases.
Be an expert in 5 minutes
Namerah enjoys geeking out over accessories, gadgets, and all sorts of smart tech. She spends her time guzzling coffee, writing, casual gaming, and cuddling with her furry best friends. Find her on Twitter @NamerahS.
