Best cases for Pixel Tablet 2025
These cases for the Pixel Tablet are functional and protective.
Despite being a few years old, the Google Pixel Tablet is still an excellent smart home controller, and it's still the only official Google tablet. It's one of the more affordable Android tablets on the market, and is more powerful than traditional smart home displays, like the Nest Hub or Nest Hub Max. To keep your Pixel Tablet safe when it's not docked, we recommend pairing it with a protective case.
Our top pick overall is the official Google Pixel Tablet Case. It has a versatile and premium metal kickstand plus a silicone exterior. If you're looking for something tougher or cheaper, check out all the options below.
Prep your Pixel Tablet for unexpected tumbles with these cases
Colors: Porcelain
Google's pricy silicone and polycarbonate Pixel Tablet Case feels sturdy and it's built well. This first-party case has a thin metal stand on the back that's compatible with the Charging Speaker Dock. It's good for everyday use, but the stand can be flimsy on soft surfaces like a couch or bed.
Colors: Kinda Coral, Off White, Black
This sleek case from Speck has a sturdier kickstand compared to the original Pixel Tablet Case and it offers better drop protection. The StandyShell Case works spectacularly with the Charging Speaker Dock and it has an antimicrobial layer that kills germs.
Colors: Black, Dark Green, Gray
You don't need to spend big money for a nice case. Just look at the MoKo Google Pixel Tablet Case. It's a sleek synthetic leather case with a folio and a magnetic clasp. The folio can be used as a stand to prop up the tablet and there's a cutout on the back for the magnetic dock.
Colors: Hazel, Black, Rose
Safeguard your Pixel tab in the most durable and robust sense with the Poetic TurtleSkin for the Google Pixel Tablet. This heavy-duty case is tough, impact-proof, and compatible with the Charging Speaker Dock. It isn't too expensive either, which is a bonus point.
Colors: Black
If you're looking for a folio cover, the Speck MagFolio Google Pixel Tablet Case is a fine choice. You get a magnetic folio that folds away to act as a stand, and the Pixel Tablet cover works perfectly fine with the Charging Speaker Dock.
Colors: Gray
If you'd prefer a thin and light case, the Spigen Thin Fit Pro is a strong pick with hard coverage around the screen edges and back of the tablet. It has a fabric back that matches with the charging dock's design, but may be a bit too slippery for some.
Colors: Black, Clear
This slim fit case from Foluu for the Pixel Tablet is the perfect 'invisible' protection for those that want minimal bulk. The case come in black and clear finishes and doesn't add much heft or thickness to the tablet. The reinforced protection for the corners absorbs shock if dropped, and the cutout on the back lets you easily dock the Pixel Tablet to the Speaker Dock.
Colors: Gray, Navy, Turquoise, Blossom, Glittering Marble, Lilac Marble
The Fintie Google Pixel Tablet Folio Case comes in a bunch of colors and designs and offers full protection when closed. This folio case offers three viewing angles for using the tablet on a flat surface, and the cutout on the back lets you dock it to the Speaker Dock when the case is closed or open. You get an elastic hoop for a stylus and a large wallet-styled pocket on the outside.
Colors: Black
There are rugged cases and then there's the Dexnor full-body protection case for the Pixel Tablet. This heavy-duty case comes with a front cover as well which offers 360-degree protection. The rear flap for the charging dock acts as a stand, and there's a holster on the back for a stylus.
These Pixel Tablet cases are really clever
A typical case does the bare minimum, which is covering up your device in a manageable layer of protective materials. What makes a case stand out is maintaining functionality and while improving protection. You should also bear in mind that some cases are designed for the rugged outdoors, whereas others are meant to be used at home. Even for indoor use, you need to choose the right case carefully. For instance, you can't rock a flimsy cover when using your Pixel Tablet in the kitchen.
We recommend the Speck StandyShell Case as the best everyday case for your Google Pixel Tablet. Since it's certified by Google, this Pixel Tablet accessory fits like a glove and delivers all of its promises. You get a sleek yet durable case with a kickstand on the rear and it is compatible with the Charging Speaker Dock. There are three colors that match the Pixel Tablet's shades. It is also much cheaper than the official case from Google.
Not everyone wants to spend around $50 on a tablet accessory, which is where the MoKo Google Pixel Tablet Case comes into play. For less than half the price of Speck and Google's offerings, MoKo's Pixel Tablet Case gives you a trifold design with a folio cover that acts as a stand, reinforced corners for protection, and a cutout on the back for seamless magnetic attachment to the dock.
While we certainly don't want to see the Pixel Tablet die, the fact that Google is ending Android OS updates for it in 2026 makes it not the most future-proof of tablets to buy in 2025. If you don't care about staying on the latest version of Android then it's okay but for others, you might want to check out some of the other best Android tablets in the market that'll last longer.
Namerah enjoys geeking out over accessories, gadgets, and all sorts of smart tech. She spends her time guzzling coffee, writing, casual gaming, and cuddling with her furry best friends. Find her on Twitter @NamerahS.
- Roydon Cerejo Contributor
- Brady Snyder Contributor
- Samuel Contreras
