Best Anker power banks
No matter what your requirement, Anker has a backup power source for all your smart devices.
You are now subscribed
Your newsletter sign-up was successful
As powerful as our modern-day smart devices are, they still need power in order to work their magic, and almost all of them require charging at least once a day. Now, since it's not always possible to be near a wall outlet, it's essential to have some kind of backup power at all times. This is where power banks come into the picture. While there are many brands out there, we particularly like the range offered by Anker. Here are some of the best Anker power banks that'll help you in keeping everything from your smartphones to your laptops fully juiced up, anytime and anywhere.
Check out the best Anker power banks you can get
Staff pick
It isn’t the newest thing out there, doesn’t offer too much in terms of capacity, or even maximum output wattage, but the 10,000mAh PowerCore III continues to be one of the best power banks you can get. It has Anker’s excellent charging tech, both USB-A and USB-C ports, wireless charging, and even comes with a built-in stand. In terms of charging speeds, you get 18W PD wired and 10W wireless, which is adequate for most devices.
Small package, big power
When you are heading out and want some quick backup power for your phone, Anker's 511 is perfect. Having a battery capacity of 5,000mAh, it supports a maximum 20W output via its USB-C port and is great for keeping your smartphone topped up while you're on the move. The compact size allows the power bank to fit in just about any pocket or bag, and it even has an integrated foldable plug that makes this thing a wall charger.
Big time power
When you need significant power output and lots of battery, we suggest taking a look at Anker's 737. Thanks to the 140W output from its dual USB-C ports, it can easily charge laptops and other bigger devices. The power bank also features a USB-A port with 18W output for smaller devices such as smartphones. You get a total battery capacity of 24,000mAh, and there's a built-in smart digital display, too for keeping tabs on important information.
Sleek powerhouse
Combining lots of power in a thin design, Anker's 523 gives you 10,000mAh of battery backup anytime and anywhere. The slim power bank features a USB-C port with a 20W power output for juicing up your smartphones and other devices in no time. You also have a regular USB-A port with a 12W power output for other gadgets. Anker 523 also looks as good as it works, thanks to its matte exterior and status LEDs that let you keep tabs on the battery charge level.
Ultimate all-in-one solution
Like the 511, Anker's 733 can also be directly plugged into a wall outlet, but there's a lot more to it than that. With the company's GaNPrime technology, you can get up to 65W of power output from this compact device. It works great for a range of devices, including everything from laptops to smartphones and has two USB-C (one in/out and one out) ports, and a USB-A port. It has a 10,000mAh battery and is backed by a 24-month warranty.
Value for money
Packing a battery capacity of 20,000mAh into a well-priced and smartly designed product, Anker's 525 offers a lot of bang for your buck. It comes with a 20W USB-C port and an 18W USB-A port, allowing you to effortlessly charge a wide array of devices, both big and small. The power bank's durable textured exterior not only makes it look good but also provides protection from scuffs and scratches. Also, the trickle-charging mode works well for small devices such as earbuds and activity trackers.
Anker lets you keep all your smart devices charged
When it comes to backup power solutions, Anker is a name that needs no introduction. Whether you want to charge some of the best Android smartphones or a laptop like the HP Dragonfly Pro Chromebook, you can surely find something you'd love among these best Anker power banks available out there.
Our top vote goes to the PowerCore III, which offers everything from both USB-C and USB-A ports to a built-in stand. Not just that, it supports wireless charging and is one of the best Qi wireless portable chargers and power banks in the market. We also love the 511, which gives you a 5,000mAh battery backup in a design that lets you stash it anywhere. Anker's 733 is ideal for those who are always on their devices and offers 65W of output despite its small size, thanks to GanPrime technology. Do take a look at Anker 525 as well, which gives you 20,000mAh of backup power, 20W USB-C and 18W USB-A charging, and more at a very reasonable price.
