Shokz OpenFit Air and OpenSwim Pro review: 'Wow!' moments in the water
Both of these headphones will satisfy your open-ear needs, but the OpenSwim Pro is perfect for underwater use while the OpenFit Air targets budget buyers.
OpenSwim Pro surprised me!
(Image: © Tshaka Armstrong)
Android Central Verdict
Shokz OpenSwim Pro and OpenFit Air have some surprisingly effective features. The OpenSwim Pro is unlike anything I've experienced in the water. Actually, it's the only audio product I've experienced that way. The bar is set high, and if you spend a lot of lap time at shallow depths, it's amazing! I highly recommend it. OpenFit Air differentiates itself from the more expensive OpenFit in a few ways, including being easier on the wallet. They're definitely worth checking out if you need unobstructed ear canals for outdoor exercise, your work environment, or because you don't like in-ear or over-ear products.
Pros
    Glasses and ear-piercings friendly
    Unobstructed ear canals (situational awareness)
    Underwater audio quality (Pro only)
    Battery life
    32GB Standalone MP3 functionality (Pro only)
    Weight/comfort
Cons
    Light on the bass response
    Ticklish folks may find them irritating (Pro)
    Not "pocketable"
    Not salt water friendly (Pro)
Open-ear or bone-conduction audio tech is niche, but there are legitimate reasons why people need uncovered ears when running or working outdoors. If that applies to you, Shokz has been at the forefront of those technologies and continues to prove themselves with their latest products.
"Niche" may be the first word that comes to mind with Shokz's OpenSwim Pro bone conduction headphones. But after I swam my first lap and took my first sustained underwater plunge wearing the OpenSwim Pro, the next word that came to mind was "impressive."
By comparison, the affordable OpenFit Air aren't quite as distinct. But that's okay: they're more likely to appeal to non-swimmers or anyone on a budget.
Shokz OpenSwim Pro, OpenFit Air: Price and availability
Shokz OpenFit Air, and OpenSwim Pro
(Image credit: Tshaka Armstrong)
Shokz OpenFit Air is available today, June 5th, in black, white, and pink. You can pick them up for $119.95. OpenSwim Pro is available today in two colors, grey or red, for $179.95.
With the OpenFit Air, it's hard to tell how often you'll be able to pick them up for less than MSRP, though they've seen price drops on Amazon almost monthly since December 2023. OpenSwim was on sale bi-monthly, but that may have been an early incentive to purchase due to it having fewer features than the new OpenSwim Pro.
You can buy both devices directly from Shokz.com or Amazon.com right now. If a trip to the brick-and-mortar is more your speed, they're available at Best Buy.
Swipe to scroll horizontally
CategoriesOpenSwim ProOpenFit Air
ConnecitvityBluetooth 5.4, Multipoint supportBluetooth 5.2, Multipoint support
DriverBone conduction transducer18x11mm composite dynamic
Frequency response20 Hz~20 KHz50Hz-16kHz
Codec supportSBC, AACSBC, AAC
Battery 160 mAhEarbuds: 40mAh; Case: 600mAh
Charging4-Pin Magnetic Charging Cable, Quick charge: 10 minutes for 3 hours playbackUSB-C, Quick charge: 10 minutes for 2 hours playback
App supportShokz app for Android & iOSShokz app for Android & iOS
ColorsGrey, RedBlack, White, Pink
DurabilityIP68 (2 meters for up to 2 hours)IP54
OpenFit Air: What I like
Shokz OpenFit Air
Let's begin with the OpenFit Air. There are a few reasons someone may want an open-ear product like this. They could have a few piercings in one or both ears. Maybe they don't like the feeling of in-ear devices. Then there are the usual use cases you read about: outdoor exercise or a worksite that requires unobstructed hearing.
Either way, it's important to note first that the trade-off with having your ear canals unobstructed is the depth of bass you will get. It's simple physics, and there's really no way yet to overcome that. Some, like Bose, have come quite close, but you'll pay almost three times more for those than for the OpenFit Air.
Speaking of paying more, what differentiates the OpenFit Air from the Shokz OpenFit besides price? As the name suggests, although their weight difference is negligible, the new Air unit feels lighter than the OpenFit. Shokz took user feedback and moved the battery from the stem portion behind your ear on the OpenFit model to the module over your ear in the OpenFit Air.
Curve of the driver module: Shokz OpenFit Air versus OpenFit
Curve of the driver module: Shokz OpenFit Air versus OpenFit (Image credit: Tshaka Armstrong)
Then, they added more curves to the entire earbud and the module that houses the 18 x 11mm custom composite dynamic driver unit. The earbud now sits at a 25.5-degree angle while the beveled driver housing sits at 18 degrees, so it fits better in your ear than the OpenFit.
Shokz OpenFit Air being worn by Tshaka
In my testing and comparing the two units, I think this new fit will benefit some and be a negligible difference for others. I like the heavier feel of the OpenFit, and I have terribly small ear canals, so the smaller driver module of the OpenFit works fine for me. That said, the OpenFit Air does feel lighter and just as comfortable to wear for extended periods without feeling like it's flailing around the outside of your ear as some open earbuds do.
Sound out of the OpenFit Air has solid clarity in the mids and highs, with good separation in the stereo image. OpenFit Air sounds pretty good as open-ear products go, thanks to the OpenBass Air low-frequency algorithm and Shokz DirectPitch technology, which pushes sound directly into the ear while minimizing leakage.
The genres that shine brightest with the OpenFit Air tend to be pop, rock, folk, and classical. Hip-hop is fine. You'll be light on the "Boom" but still get decent "bap." Switching from music to movies, I didn't experience any latency in dialog, and the bass reproduction was satisfying enough to give action sequences in movies or anime the enjoyable thump they should have. And with movies that feature 5.1 audio, the stereo image these produce is solid.
Shokz OpenSwim Pro: What wowed me
Swimming laps wearing the OpenSwim Pro
The previous OpenSwim product escaped my notice. Likely because it was just a standalone MP3 player in the body of a pair of bone-conduction headphones. I don’t swim often, so they weren't my jam. Shokz may have felt that sentiment from more users than me, so the OpenSwim Pro is no longer a one-trick seahorse.
You still get the MP3 player with an increased 32GB of storage for MP3, WMA, FLAC, WAV, AAC, M4A, and APE files. That's more storage than any competing product. Depending on which file types you use, you can cram around 8,000 songs into them — plenty for an Ironman or two. Now, though, you get more utility out of them with the included Bluetooth 5.4 radio so that when you aren't in the pool, you can stream music, movies, podcasts, or whatever you fancy, right from your phone.
What's most interesting about these headphones is their underwater sound quality. It is seriously impressive. I'd almost say that they sound better underwater! Imagine that. This underwater awesome is achieved by OpenSwim Pro having triple-sealed components rated for IP68 dust and water ingress which means you're good up to (two meters) six feet deep for up to two hours. That's the first part.
Once you're in the pool, you can switch the headphones to MP3 mode and choose the Swimming EQ preset (you also have a Standard EQ preset). The Swimming preset flattens the sound profile, sounding tinny out of the water and killing bass response but giving you an underwater listening experience that is highly impressive. The bass magically reappears, giving you a delightfully robust sound as you hit those freestyle strokes or do some underwater laps.
Just don't pass six feet of depth, since it could damage the OpenSwim Pro.
OpenSwim Pro volume/power buttons
OpenSwim Pro volume/power buttons also switch modes. (Image credit: Tshaka Armstrong)
The best part of this swimming tech is that you don't need the app to access it. You can simultaneously press the volume down and volume up/power buttons to switch the OpenSwim Pro from Bluetooth to MP3 mode. The controls — the large multifunction button on the front and those volume buttons underneath the right arm of the headband — are just as responsive wet as they are dry.
Below those volume buttons is the proprietary four-pin magnetic charging port. To keep everything sealed and protected against water ingress, you'll use pogo pins instead of USB-C.
OpenSwim Pro case drainage holes
The fine folks at Shokz also considered the case when it comes to getting wet. It's wedge-shaped so it can stand up and has drainage holes on the back to accommodate airflow for damp headphones drying. Being upright ensures those drainage holes don't get blocked.
Overall, on land, the audio quality from the OpenSwim Pro is really good, with a caveat I'll get to in a moment. They have excellent sound separation in MP3 mode and Bluetooth mode. You have to remember that you're using open-ear audio devices, so there's a level of warmth from the mids and lows that you aren't going to get like in-ears, but despite that, the audio output is pleasing.
Shokz OpenSwim Pro, OpenFit Air: What could use improvement
There isn't much I take issue with regarding both of these devices, but for the OpenSwim Pro, the bass passed through the bone conduction pads may get annoying for some people and too much for those who are ticklish. It vibrates a lot! Like "PS5 gaming remote haptic feedback" a lot. I think this is a feature that some people will accept but others will hate.
Sorry to be a wet blanket, triathletes, but I have to mention the inability to use these earbuds in salt water. So, no ocean use for you. If you do happen to purchase the OpenSwim Pros and try them in that deep blue sea, Shokz recommends that you wash them off with fresh water and dry them immediately.
One other thing I'd like to see on future OpenSwim Pro units is the ability to adjust the neck, or is it a head-band? For me it sits at the base of my skull, so technically, I guess that makes it a headband.
Despite the new angled design, the OpenFit Air feels "loose," hovering over my ear. For my ear geometry, the OpenFit feels like it sits closer to my ear, but ears are like fingerprints; no two are the same, so your mileage will vary in how they feel on you.
The last thing you may have an issue with is the case size. It's a hair larger than the previously released OpenFit, so it is "purse-able," but pocketable? Not really. It's going to leave quite the imprint sitting in your pockets.
Competition
Anker Soundcore AeroFit and AeroFit Pro
If swimming gear is what you're looking for, there are actually a few other options on the market, and we have an entire roundup of open-ear earbuds to consider if it's the OpenFit Air you were curious about. First, let's talk OpenSwim Pro competitors. The H20 Audio Tri Multi-Sport has a nice, warm bass-heavy sound but, unlike the OpenSwim, only has 8GB of storage for music. They're $20 less but are only rated for water ingress, not dust, and their controls can be finicky.
The Zygo Solo takes a novel approach to keeping you in the water and entertained by using an FM radio transmitter, which does a lot better than Bluetooth underwater. The downside is that compared to the OpenSwim Pro's nine hours of battery life, you'll get just three hours. Oh, and they're a lot bigger than the OpenSwim Pro.
There are a couple of others, but they lack either the battery life, the storage capacity, or the sound quality of the OpenSwim Pro.
For OpenFit Air competition, the premium upgrade that gives you upgraded sound, a jaw-dropping "Immersive Sound" mode, and better battery life if you don't use that immersive mode is the Bose Ultra Open earbuds. These are almost three times the cost, though. You'll pay $299 ordering them from Amazon.
1MORE Fit Open Earbuds S50 have a long name and an even longer battery life: 11 hours. They're IPX7, so no dust ingress rating, and they'll cost you $10 more. People with smaller ears may experience fit issues with these.
Anker also offers some competition in their Soundcore AeroFit Pro, which gives you an impressive 14 hours of playback time and supports LDAC playback. They come with a detachable neckband to shore up the fit for those high-intensity workouts and they sound great at lower volumes.
Shokz OpenSwim Pro, OpenFit Air: Should you buy them?
Shokz OpenFit Air and OpenSwim Pro group photo
You should buy OpenFit Air if...
  • You want relatively inexpensive open-ear earbuds
  • You have concha piercings and in-ears don't fit
  • You want open-air earbuds that sound good
You shouldn't buy OpenFit Air if...
  • You are a bass lover
  • You need more than 6 hours of battery life
You should buy OpenSwim Pro if...
  • You spend a lot of time in the water
  • You want something with great sound submerged
  • You want something for surf and turf
You shouldn't buy OpenSwim Pro if...
  • You're very ticklish. Seriously.
  • You don't like neckband configurations
  • You need earbuds that can withstand salt water
If you want a product that will "Wow!" you underwater, the OpenSwim Pro is that product. It has nine hours of battery life (six hours in MP3 mode), is IP68 rated for two hours in the pool at up to six feet deep, and has an MP3 mode with 32GB of storage, making it a hard product to beat in this category. Best of all, Bluetooth 5.4 makes it… not so niche. Despite the potentially ear-tickling bone conduction modules, the OpenSwim Pro is easily recommended for the mermaids and mermen among us (Mer-persons?).
OpenFit Air has stiff competition in the open-ear market. Still, its light weight, solid sound, IP54 rating, wallet-friendly price point, and good call quality make it a good all-around open-ear earbud for those who need or prefer this design.
Tshaka Armstrong
Contributor
Tshaka Armstrong is a nerd. Co-Founder of the non-profit digital literacy organization, Digital Shepherds, he’s also been a broadcast technology reporter, writer and producer. In addition to being an award-winning broadcast storyteller, he’s also covered tech online and in print for everything from paintball gear technology, to parenting gadgets, and film industry tech for Rotten Tomatoes. In addition to writing for Android Central, he’s a video contributor for Android Central and posts everything else to his own YouTube channel and socials. He blathers on about his many curiosities on social media everywhere as @tshakaarmstrong.
Read more
A photo of the reviewer wearing the Shokz OpenFit 2, with its ear hook looped next to his glasses.
Shokz OpenFit 2 review: Wow, do I love these
A woman wearing an athletic tanktop and the white Shokz OpenFit 2 wireless earbuds with her eyes closed, listening to the music, with a purple sky and a distant building skyline behind her.
My favorite (flawed) workout earbuds got a much-needed upgrade at CES 2025
Honor Earbuds Open photos
Honor Earbuds Open review: Unmatched comfort, unbelievable sound
Powerbeats Pro 2, showing the PPG heart rate monitor sensors
Beats Powerbeats Pro 2 review: Great earbuds with accurate heart rate monitoring
Jabra Elite 8 Active Gen 2 earbuds loose and wet in front of case.
Best workout earbuds & headphones 2025
Tshaka wearing 1MORE Fit S50 and Bose Ultra open earbuds
Best open-ear earbuds 2025
Latest in Audio
Tagry X08 earbuds in-hand
These are the best-sounding budget earbuds I've ever used, and they're just $25 right now
Google Pixel Buds Pro 2 Wintergreen earbud
Google reveals Pixel Buds Pro 2 cleaning tips that can 'greatly affect' sound
AirPods Max (left) hanging from a park bench beside Beats Studio Pro (right).
USB-C AirPods Max are getting an upgrade Android headphones had all along
Soundcore Liberty 4 Pro showing smart screen Ambient Sound menu
Soundcore Liberty 4 Pro review: Great budget earbuds with some fun tricks!
The orange Powerbeats Pro 2 next to the Navy original Powerbeats Pro.
Score! The original Powerbeats Pro are now $70 off, but the deal gets even better with some freebies from Best Buy
Latest in Review
Kobo Libra Colour review
Kobo Libra Colour review: The obvious upgrade to the Kindle Oasis
Honor MagicPad 2 review
Honor MagicPad 2 review: This mid-range tablet has a unique OLED advantage
Apple iPhone 16e review against colorful background
Apple iPhone 16e review: Elevated basics
A OnePlus Watch 3 with a blue watchface
OnePlus Watch 3 review: The best battery life, but not a great fit for everyone
Comparing the transparent backs of the grey Nothing Phone (3a) Pro with the white Nothing Phone (3a)
Nothing Phone 3a and 3a Pro review: Nothing is Essential
