This 8-in-1 USB-C Hub adds more versatility to your computer at over 50% off
Your computer is capable of so much, and with the VAVA 8-in-1 USB-C hub, you can unlock even more of its potential. Clipping the coupon on its product page at Amazon and then entering code BQA4NMLB during checkout will drop its price to $28.49, saving you over 50% and enabling a new level of connectivity for your computer. This USB-C hub generally sells for up to $60 and hasn't dropped anywhere near this price without a promo code in the past.
This USB-C hub is packed with ports to connect flash drives, monitors, memory cards, and other devices to your computer, and they can all be used simultaneously. It's equipped with two USB 3.0 ports and a single USB 2.0 port, along with an HDMI output that supports 4K video and an RJ 45 Gigabit Ethernet port. There's also a 100W Power Delivery port that lets you charge your laptop through the hub as well as two memory card slots, SD 3.0 and TF 3.0, both with data transfer speeds up to 5 Gbps. VAVA even includes a warranty that lasts for more than two years with its purchase.
At Amazon, more than 350 customers left a review for this USB-C hub resulting in a high rating of 4.8 out of 5 stars. This item ships for free, though you'd receive your item even faster with an Amazon Prime membership.
If this hub is missing a specific port you were hoping to gain access to, there are plenty more USB-C hubs you should consider. This guide to the best USB-C hubs may be best suited for Chromebook users, though each of the USB hubs in the guide can be used with Windows and Mac computers which feature a USB-C port as well. You'll even find Vava's 8-in-1 hub included in the mix.
