This 30W USB-C wall adapter can speed up charging times for just $11
You are now subscribed
Your newsletter sign-up was successful
Powering up your devices could be much quicker if you had the appropriate charger. If you have any Power Delivery-compatible devices, then the dual-port ESR 30W USB-C PD Wall Charger is a stellar option, and today you can grab one for only $10.99. The charger usually sells for $20 which is already super affordable, but today's price drop takes almost half off making it a total no-brainer buy. You simply need to clip the coupon on its product page at Amazon to score this low price.
ESR's 30W USB-C Wall Charger is nearly three times faster than 5W chargers like the one that comes with the Apple iPhone. Its integrated smart IC chip can automatically detect and deliver the optimal charging speed for your devices, so you never have to worry about your phone being overloaded or not receiving a good charge. There are two built-in ports, including one USB-C port with Power Delivery and a standard USB port, so you can power up two devices simultaneously.
This charger was designed to be compact and features a foldable plug that makes it even smaller when packed away. With its 30W output, you can use it to power up more than just your phone. It's suitable for devices like the Nintendo Switch or even USB-C laptops.
You won't receive any charging cables with this purchase, so make sure to add some to your cart before checking out if you don't have any ready to use with it. This guide to the best USB-C cables has several great picks to choose from.
Shipping is free at Amazon on orders totaling $25 or more, or with an Amazon Prime membership. If you've never been a member before, you can start a free 30-day trial to score free two-day shipping with no order minimum, as well as perks like exclusive members-only discounts, access to the Prime Video streaming service, and more.
