This 2-pack of EufyCam 2 Wireless Security Cameras is down to a new low with $80 off
EufyCam 2
EufyCam 2 (Image credit: Eufy)
Keeping an eye on your home 24/7 isn't possible... except with the right equipment. The eufyCam 2 wireless home security system ensures you always have a way to see what's going on around your home no matter where you are, while also letting you rewind and view previously recorded footage as well.
Now, thanks to a sale at Amazon, you can snag a 2-camera kit for your home on sale for only $219.99. This $80 discount saves you over 25% off its usual cost of $300 and it even marks the lowest price we've seen for the set so far. It's a one-day deal, though, so you don't have long left to make the most of it.
Eufy cordless stick vacuums and robot vacuum cleaners
As low as $140
Choose from a cordless stick vacuum or a robot vacuum. The cordless vac includes 120AW suction power for 8 minutes or 25 minutes in standard mode. Helpful for getting into tight spaces. The robot has 1300Pa suction and lasts up to 100 minutes.
Eufy Security Wi-Fi 2K resolution video doorbell
$119.99 $160.00 Save $40
You'll get a wireless chime you can use somewhere else in the house to hear the door wherever you are. Has a 2K resolution image with advanced HDR and distortion correction. Includes two-way audio, motion detection, and smart alerts.
Eufy RoboVac 15C Max Wi-Fi connected robot vacuum cleaner
$175.99 $ Save $
Comes with super strong 2000Pa suction so it can pick up even stubborn dirt. BoostIQ feature will even boost the suction when you need it. Lasts for up to 100 minutes. Use the EufyHome app and connect it to your smart home for more control.
Eufy Spaceview Security by Anker baby monitor camera bundle
$129.99 $170.00 Save $40
Has a large 5-inch 720p display for a sharp picture. Let's you see everything your little troublemaker is doing. Can pan 330-degrees and tilt 110-degrees so you can see the whole room. Get instant alerts. Has a range up to 1,000 feet.
Eufy Security SpaceView 720p video baby monitor with night vision
$109.99 $160.00 Save $50
Has a large 5-inch 720p display for a sharp picture. Let's you see everything your little troublemaker is doing. Includes a wide-angle lens for when your baby starts moving around more. Get instant alerts. Has a range up to 1,000 feet in open area.
The EufyCam 2 greatly improves on the first-generation EufyCam E in a number of ways. You'll get more advanced A.I. powered facial recognition software that helps prevent false positives. The new EufyCam 2 can tell the difference between familiar faces, objects, dogs, birds, and other things that the old EufyCam E might have sent you an alert about. You'll also get a better IP rating for withstanding weather. The EufyCam 2 has an IP67 rating, which means it is a lot more resistant to water than the previous generation's IP65 rating. It also comes with an 8x digital zoom, which is something the original does not have.
In addition to all of that, the camera has 16GB local storage that can store up to a year's worth of video, a battery that can last 365 days on a single charge, 1080p video recording, night vision that works up to 25-feet away, two-way audio, and a 140-degree wide-angle lens so you can capture all around your home.
The camera also has sophisticated smart home integration. You can connect the camera system to your Wi-Fi and control it from your smartphone. You'll also be able to use voice commands through Amazon Alexa, Google Assistant, and Apple's HomeKit, which is another new feature for the series, though you'll need a smart speaker like the Echo Dot smart speaker to make use of that functionality.
If you're in the market for more home security deals, check out our list of the best Ring deals available right now for some more ways to save.
Adam Oram is a Senior Writer at iMore. He studied Media at Newcastle University and has been writing about technology since 2013. He previously worked as an Apple Genius and as a Deals Editor at Thrifter. His spare time is spent watching football (both kinds), playing Pokémon games, and eating vegan food. Follow him on Twitter at [@adamoram](https://twitter.com/adamoram).
