Everyone likes to tweak their device a little, and one of the apps that can help you achieve some visual and functional tweaks is WidgetLocker Lockscreen. Having been updated to v2.2 -- some new sliders have been added such as the ones from Ice Cream Sandwich, Honeycomb and Sense 3 which can give your device lockscreen a whole new look. Some other additions came with the update as well as some bug fixes:
- Customizable Clock
- Tablet Optimizations, Hardware Acceleration
- Improved Preferences and Slider Setup Interfaces
- User selectable app shortcut icons
Fixes:
- Moto OTA Conflict (Battery problems)
- Keyboard focus bug (SMS Popup apps)
- Ice Cream Sandwich Compatibility
- Unlock-With-WiFi Compatibility
- Misc fixes and optimizations
We've written up a quick app review WidgetLocker Lockscreen previously, so if you're looking to learn more make sure you give it a look. You'll find the download link to the latest version past the break, remember -- it is a paid app but well worth the buy in cost if you're looking for easy tweaks.
Be an expert in 5 minutes
