Verizon introduces LTE network extender for homes and businesses
Verizon and Samsung have revealed a 4G LTE network extender aimed both at consumer and business customers. As you might guess, the box extends the reach of Verizon's network in your home or office, allowing you to get strong cellular signal wherever you go.
From Verizon:
The 4G LTE Network Extender features Samsung's innovative small cell technology, which enables Verizon subscribers to make HD Voice and Video calls, access mobile data, and stream content from in-building locations where existing cellular coverage may not adequately reach. The product provides a cost-effective and simple-to-install solution to overcome the challenges of weak coverage in buildings with dense materials or located in remote areas — helping significantly boost productivity for offices and residences.
The Network Extender is meant to offer strong LTE connections for up to 7 devices, and has an eighth channel reserved for 911 calls. It features self-optimization network technology from Samsung that allows it to automatically adjust coverage based on needs.
You'll be able to get the 4G LTE Network Extender directly from Verizon beginning June 30 for $249.99.
Be an expert in 5 minutes
