Pocket this compact Power Delivery and QC 3.0 portable USB-C charger at nearly 60% off
If you're dealing with a dead battery more often than you'd like to, you could probably benefit from something like the Xcentz 5000mAh Portable Power Delivery and Quick Charge 3.0 USB-C Charger. Clipping the coupon on its product page and then using promo code XCENTZ215 during checkout at Amazon will bring its price down to $8.99 there and save you $13 off its average cost of $22. Only the black model of this charger is eligible for this discount.
Powered Up
Equipped with Power Delivery and Quick Charge 3.0 technology, this tiny portable charger can recharge your devices twice as fast compared to standard options. You'll just need to clip the coupon on its product page and then enter the promo code below to snag this offer.
$8.99 $21.99 $13 off
This compact battery charger is small enough to fit into your pocket easily, or you could store it in your backpack or luggage without taking up hardly any extra space. With Power Delivery and Quick Charge 3.0, you can recharge your devices much quicker than with standard models, saving hours of time in the process. It even includes a USB-A port on the opposite end so you can charge two devices simultaneously, along with protections against overcharging, short-circuiting, and overheating.
A USB-A to USB-C cable is included with its purchase, along with a 2-year warranty, though you'll want to have a USB-C to USB-C cable to use the port with PD and QC 3.0 technology. You'll also need a way to charge up the power bank as well, and the most efficient method is with a USB-C wall charger.
Be an expert in 5 minutes
