Sony's WF-1000XM3 true wireless earbuds have dropped back down to their lowest price
The Sony WF-1000XM3 noise-cancelling true wireless earbuds have dropped to $198 on Amazon. These earbuds normally sell from $230 and they are new enough that they have not dropped from that price very often. We saw them drop this low briefly for a couple of days about a week ago, but that deal had expired until now. You can find these savings at several retailers including B&H. You can also choose to get them in Silver at the same price instead of black.
Uses QN1e HD noise-cancelling processor and 24bit audio signal processing. Battery lasts up to 24 hours and has a 10 minute quick charge. Automatically switches to ambient sound mode based on activity. Uses USB-C for charging.
The Sony earbuds use indsutry-leading noise-cancelling technology with a QN1e HD processor, and they have 24bit audio signal processing for improved sound quality. That means you get a full range of powerful sound without the distracting noises of the everyday world around you.
Plus, the earbuds have smart listening technology that automatically switches to an ambient sound mode based on your activity. While you might not want to hear a lot of the noises around you while listening to your favorite music, sometimes it is necessary. You can connect to the companion app on iOS or Android to access the smart listening technology and control your ambient sound settings.
The touch controls on the earbuds allow you play and pause your media, control your smartphone's voice assistant, and answer phone calls with just a tap to your ear.
Each earbud lasts for up six hours, and you can get a total of 24 hours before having to plug in with the charging case. The earbuds also support quick charge, so you can juice up for 10 minutes and get 90 minutes of playtime.
You will get a set of triple comfort earbuds and long hybrid silicone rubber earbuds so you can find the perfect fit for your ears. The cases charges using an included USB-C cable.
John Levite
