Samsung audio dock images leak out, could be seen at CES
Audio docks are pretty common over in the iOS camp, with a wide array of OEM's getting behind Apple's devices to create such accessories. Over here in Androidland, things aren't quite so plentiful. Samsung seems set to make a change to that if the leaked images we see here ring true.
The leak was obtained by the guys over at Sammobile -- usually known for their firmware leaks -- and they claim it could be seen in the wild at either CES, next month in Las Vegas, or at Mobile World Congress, in Barcelona in February. They look pretty good, but with a speaker of course, that's only half the story. The images were accompanied by a set of leaked specs:
- USB Audio Class
- Universal dock station
- Bluetooth version 3.0
- Power: 6W (3W x 2)
- Power volume button
- Charging Port
- 3.5mm Audio Plug-in
The beauty of course, is that any Android device with a bottom mounted microUSB charging port will be able to take advantage of the charging facilities.
Source: Sammobile
Be an expert in 5 minutes
