Open Signal: Verizon and T-Mobile are in a virtual tie for the best network in the U.S.
T-Mobile CEO John Legere
T-Mobile CEO John Legere (Image credit: Android Central)
Open Signal has released their State of Mobile Networks: USA report and they say Verizon has now tied T-Mobile for the fastest carrier in the United States, and the results are so close between the two that they are virtually tied for the "best."
Using data collected from 169,683 users, 4,599,231,167 data points were used to measure network speeds on both 4G and 3G, network availability and latency. The data is collected by users installing the Open Signal app from Google Play or the App Store and going about their daily routine.
In their analysis of the collected data, they say that Verizon has improved their 4G network speeds to pull even with T-Mobile who has traditionally done well in this category. They also mention that the average overall network speeds in the U.S. have risen slightly, and over 81% of U.S. residents have access to LTE networks.
Availability of high-speed data services shows that all four carriers have improved, but T-Mobile (86.6%) is now within two percentage points of Verizon (88.2%) when it comes to finding an LTE signal. The company with the most improvement here is Sprint, who jumped from covering 69.9% in August to 76.8% in February 2017.
Verizon or T-Mobile performed the best in every category tested, and the final results show that any measurable advantage T-Mobile or Verizon previously held in nationwide network testing has shrunk to the point of being insignificant. You still need to pick the carrier service that works bets for you, but overall either Red or Magenta should have you covered.
The best part is that they now need to fight even harder for our dollars.
Jerry Hildenbrand
Senior Editor — Google Ecosystem
