OnePlus 8 Pro vs. Motorola Edge Plus: Which should you buy?
OnePlus 8 Pro
OnePlus 8 Pro (Image credit: Daniel Bader / Android Central)
OnePlus 8 Pro
Oneplus 8 Pro
The OnePlus 8 Pro is the first phone where OnePlus truly didn't hold back at all, and the end result is rather impressive. From a 120Hz AMOLED display, Snapdragon 865, IP68 dust/water resistance, and an all-new wireless charging experience, the OnePlus 8 Pro does a lot to justify its high price.
OnePlus 8 Pro
Has it all
Beautiful 120Hz AMOLED display
Performance is buttery smooth
Long-lasting battery life
Super-fast wireless charging
OxygenOS software is unmatched
So-so telephoto camera
Motorola Edge+
Motorola Edge Plus
After years of owning the budget market, Motorola has returned to the flagship scene with the Edge+. This is another phone that has a lot to like, with some highlights being a 90Hz display, blazing-fast performance, and a huge battery. The biggest downside is its Verizon exclusivity, which is a non-starter for many shoppers.
Motorola Edge+
Verizon exclusive
A truly eye-catching display
Easy to use in one hand
Massive 5,000 mAh battery
There's a headphone jack
Motorola's excellent software features
Curved display comes with some issues
No official waterproofing
Exclusive to Verizon
For some people, deciding whether to get the OnePlus 8 Pro or Motorola Edge+ is pretty simple. If you rely on AT&T or T-Mobile as your carrier of choice, the 8 Pro is the way to go given that the Edge+ is only available at Verizon. If you are a Verizon customer, however, things are a bit trickier. The OnePlus 8 Pro has a more technically-impressive display, legit water-resistance, faster wireless charging, and you could potentially save $100 if you go with the baseline model. The Edge+ does have a few drawbacks given its large price tag, but between the gorgeous waterfall display, larger battery, and the presence of a 3.5mm headphone jack, some people will be better off going the Motorola route.
The OnePlus 8 Pro is a force to be reckoned with
Ever since the original OnePlus One came out in 2014, OnePlus has become iconic for releasing high-specced Android phones with considerably lower prices compared to traditional flagships. With the 8 Pro, OnePlus abandons that idea and just goes full-on flagship. The end result is darn impressive.
Starting with its display, you're treated to a 6.7-inch AMOLED screen with a crisp 3168x1440 resolution. Pair that with a ridiculously smooth 120Hz refresh rate, and this is easily one of the best smartphone displays on the market in 2020.
Swipe to scroll horizontally
Header Cell - Column 0 OnePlus 8 Pro Motorola Edge+
Operating System Android 10
OxygenOS 10
Android 10
My UX
Display 6.7-inch
Fluid AMOLED
3168 x 1440
19.8:9 aspect ratio
120Hz refresh rate
6.7-inch
OLED
2340 x 1080
19.5:9 aspect ratio
90Hz refresh rate
Processor Qualcomm Snapdragon 865 Qualcomm Snapdragon 865
RAM 8GB
12GB
12GB
Storage 128GB
256GB
256 GB
Expandable Storage
Rear Camera 1 48MP primary camera
f/1.78 aperture
108MP primary camera
f/1.8 aperture
Rear Camera 2 8MP telephoto camera
f/2.4 aperture
3x hybrid zoom
f/2.4 aperture
3x optical zoom
Rear Camera 3 48MP wide-angle camera
f/2.2 aperture
119-degree FOV
16MP wide-angle camera
f/2.2 aperture
117-degree FOV
Rear Camera 4 5MP color filter Time-of-flight sensor
Front Camera 16MP
f/2.4 aperture
25MP
f/2.0 aperture
Battery 4,510 mAh 5,000 mAh
Charging Warp Charge 30T
Warp Charge 30 Wireless
18W Turbo Power
15W wireless charging
5W wireless power sharing
Audio Stereo speakers
USB-C
Stereo speakers
Carrier Compatibility AT&T
T-Mobile
Verizon
Verizon
Dimensions 165.3 x 74.3 x 8.5mm 161.07 x 71.38 x 9.6mm
Weight 199g 203g
Oneplus 8 Pro
Source: Daniel Bader / Android Central (Image credit: Source: Daniel Bader / Android Central)
Powering the OnePlus 8 Pro is a Qualcomm Snapdragon 865 processor, your choice of 8 or 12GB of RAM, and a generous 4,510 mAh battery. Performance is as fast and smooth as you could ask for, and this is also helped by OxygenOS — the custom Android interface OnePlus makes for its phones. It's clean, doesn't have unnecessary bloatware, and OnePlus adds genuinely great customization tools and other features that only elevate stock Android. OnePlus is also one of the better companies in the business when it comes to software updates.
Looking at the back of the OnePlus 8 Pro, you'll find an impressive setup of cameras. The telephoto sensor isn't the most impressive we've ever seen, but the 48MP primary camera is able to take great shots whether it's light or dark out. The 48MP ultra-wide camera is good, too, kicking out vibrant colors and a lot of detail.
What else about the OnePlus 8 Pro stands out? There's an IP68 rating for dust and water-resistance, 30W wired and wireless charging, and it works on AT&T, T-Mobile, and Sprint. Not to mention, the Glacial Green and Ultramarine Blue colors are downright gorgeous 😍.
Why you shouldn't sleep on the Motorola Edge+
Motorola Edge Plus
The OnePlus 8 Pro is a tough phone to beat, but lucky for Motorola, the Edge+ is a worthy competitor.
On a technical level, the Edge+'s display isn't as impressive. It has a lower resolution and refresh rate compared to the 8 Pro, but in real-world use, it still looks great. The Edge+ also gets its name from its waterfall-like display, which seamlessly flows over the edges of the phone. Not only is it a sight to behold, but Motorola also added some unique software tweaks to take advantage of the drastic curves. Rounding all of this out is the unconventionally narrow 19.5:9 aspect ratio, which makes using the Motorola Edge+ in one hand a great deal easier than the OnePlus 8 Pro.
Along with the display, Motorola also did a great job with the Edge+'s other specs. You get a Snapdragon 865 processor, 12GB of RAM, 256GB of storage, and the battery weighs in at a hefty 5,000 mAh — a good deal larger than the one in the 8 Pro. The cameras are also quite good, with the 108MP primary camera using pixel-binning to kick out excellent 27MP shots.
Motorola Edge Plus Review
Rounding out this experience is the Edge+'s software, which is almost as good as OnePlus's OxygenOS. Motorola is using the Edge+ to debut its new My UX interface, which is just a refinement of what the company's been doing for years — keep Android nice and clean with some helpful additions here and there. Moto Actions and Moto Display are still around and just as good as ever, and now you can customize a variety of UI elements (such as the accent color, app icon shapes, system font, etc.).
Motorola promises at least two major Android updates for the Edge+, which is much better than the original promise of just one. That said, OnePlus has a better track record when it comes to getting updates out in a speedy manner.
It all comes down to your carrier choice
Verizon logo
Source: Android Central (Image credit: Source: Android Central)
The OnePlus 8 Pro and Motorola Edge+ are both top-tier Android phones, but as noted at the top of this comparison, there's a big factor that comes into play for all of this — your phone carrier.
Motorola is only selling the Edge+ through Verizon, meaning if you don't use it for your service, you're out of luck. Even worse, you can't go out and just buy an unlocked model of the phone. Comparatively, the OnePlus 8 Pro is sold unlocked and can be used on AT&T, T-Mobile, and Verizon.
If you are a Verizon customer and can actually choose between the two, both are worth your consideration. The OnePlus 8 Pro has a technically better display, an IP68 rating, and a lower price for its base model. That said, the Edge+ gives you a headphone jack and a bigger battery. If you find one calling your name more than the other, go for it.
Joe Maring
Joe Maring was a Senior Editor for Android Central between 2017 and 2021. You can reach him on Twitter at @JoeMaring1.
