Motorola Droid Froyo build FRF84B leaked
Droid users you've got another Froyo build to play with -- FRF84B.  (Eyes playing tricks on me.  Thanks for the correction darkcomartist.Yes, that number should look familiar, as it's the same build that was called the final for the Nexus One.  We have no idea if this will be the final version from Motorola, but if you've been unofficially beta testing Android 2.2 on your Droid, you might want to have a look.
Get it HERE .  You'll have to be rooted, flash the file from recovery.  Then shout out in the comments and in the forums and let us know the good and the bad.  [DroidLife]
Jerry Hildenbrand
Senior Editor — Google Ecosystem
