Marshmallow rolls out to the T-Mobile Samsung Galaxy S6 edge+
If you're rocking a Samsung Galaxy S6 edge+ on T-Mobile, you'll want to check for an update, as the carrier is now pushing Android 6.0.1 Marshmallow to the curved smartphone. Of course, once updated, your T-Mobile Galaxy S6 edge+ will have access to all of Marshmallow's goodies, including Doze Mode, granular app permissions and more.
Since the update only just began rolling out, it may take some time to show as available for download. Still, if you'd like to check manually, you can do so in the "About Device" section of the Settings menu. After you update, you should see your system software version bumped up to G928TUVU2DPD1.
Have you received the Marshmallow update on your T-Mobile Galaxy S6 edge+ yet? Be sure to let us know what you think in the comments below and on our forums!
Cheers, Rob!
Be an expert in 5 minutes
