LG G6 undergoing extensive battery tests, uses heat pipes to prevent overheating
The LG G6 will be the first LG device to use heat pipes as a way to siphon heat away from the core components. Speaking to Korea Herald, LG's Lee Seok-jong said:
We will significantly improve the safety and quality of our new flagship smartphones as more consumers seek safe smartphones.
Sony introduced heat pipes as a way to dissipate heat in the Xperia Z2, and Microsoft did the same with the Lumia 950 XL. Samsung also started using heat pipes last year in the Galaxy S7 and S7 edge.
Incidentally, the Note 7 also featured the same cooling system, but that didn't prevent it from inexplicably catching on fire. Which is why LG is saying that it will also conduct rigorous battery tests to ensure the phone doesn't overheat:
We are conducting battery heat exposure tests to a temperature 15 percent higher than the temperature set by the international standards of the US and Europe.The battery also undergoes diverse tests such as piercing it with a sharp nail or dropping a heavy object on it from a high place.
What LG is doing isn't exactly new. All manufacturers do stringent quality tests to ensure that their phones are safe to use. But with the Note 7 debacle, we'll be hearing more about the process, and that's a good sign. The LG G6 slated to make its debut next month at Mobile World Congress.
Harish Jonnalagadda
Senior Editor - Mobile
