Hisense Sero 7 Pro Review
One of the most important factors for any device — especially 7-inch tablets — is price. It's not uncommon to hear that if something is twice the price, it should be twice as good to justify that price. When looking at the $149 Sero 7 Pro, it begs the question: are other tablets that cost an additional $50, $100, or more, that much better than Hisense's new offering?
Many potential buyers no doubt passed up this tablet completely, not recognizing the manufacturer and immediately labeling it a "no name" Chinese Android tablet. Those who frequent Android forums, on the other hand, have likely heard the buzz created by the popularity of this new budget tablet.
The question becomes — even at this price — is it worth it? With specs that match or beat the immensely popular Nexus 7 in almost even area, and at $50 cheaper, it would seem like a no-brainer. Are the improvements over the 11 month old Nexus 7 enough to bring the Sero 7 Pro up to today's spec standards? If not, does the price merit a purchase anyway? How does Hisense's hardware stack up in the quality department?
Keep on keepin' on for our full review.
Pros
- Bright, high definition display with great viewing angles. Expandable memory via microSD. Mini-HDMI out for display mirroring. Tegra 3 processor on board for NVIDIA-optimized games. Minimal "skinning" and bloatware from the manufacturer, with an almost-stock version of Android 4.2 Jelly Bean. Loud stereo speakers.
Cons
- Results of the budget pricing can be felt in some areas of the hardware build quality (understandably so). Odd addition of a screenshot button to the navigation bar. Only available with 8GB of internal memory. Ships with Android 4.2.1; missing features from 4.2.2 like hold-to-toggle Quick Settings. Walmart exclusive.
The Bottom Line
Be an expert in 5 minutes
Those looking to buy a 7-inch Android tablet today can't go wrong with the Sero 7 Pro's winning combination of feature-packed hardware and low price. It combines the Nexus 7's winning spec-list with three of its most requested missing features: HDMI out, expandable storage, and a rear camera. Potential buyers should be comfortable staying on Android 4.1.2 for the foreseeable future, as Hisense has yet to build up a track record for updates to devices stateside. Power users who can hold off their tablet purchases may want to wait for the imminent announcement of the Nexus 7 successor, which is expected to offer next-gen hardware at a similar price point -- along with fast OS updates.
Hisense Sero 7 Pro specs and hardware overview
The build materials are about what you'd expect from a $149 tablet: hard plastic all around, and a few unseemly body lines around ports and buttons. The back is textured for better grip, has an almost copper-like shine in the right lighting. There are two cutouts for the stereo speakers at the bottom, with the rear facing camera and flash at the top. Overall dimensions are 7.87 by 4.95 by 0.43 inches and a weight of 12.7oz. It's not the lightest or thinnest tablet around, but it does feel good in the hand and was easy enough for me to hold for many hours during two overseas flights.
Inside the tablet is a 1.3 GHz NVIDIA Tegra 3 CPU, 1 GB DDR2 RAM, 8 GB internal memory, Bluetooth 3.0+EDR, 802.11b/g/n WiFi, and a 4,000 mAh battery. The CPU and RAM make for speedy overall performance, both in the Android system and within apps. WiFi range is good, with the tablet having no problems seeing routers or connecting. The NFC chip worked well when using Android Beam with my other devices. Although not listed on the main spec page of Hisense USA, there is a fully functional internal GPS on board as well.
All ports are housed on the top edge of the tablet. In order from left to right: a pinhole microphone, a 3.5mm headphone jack, a micro-SD slot that supports cards up to 32 GB, a micro-USB port, and a mini-HDMI port. USB-OTG is supported, so accessories like a computer mouse, keyboard, or flash drive will work with the proper cable. The HDMI out provided good image and audio quality for all the YouTube videos I watched on my 32" LG LCD TV.
On the tablet's right side, you'll find the power button and volume rocker. Controlling volume using the rocker worked without a hitch. The power button, on the other hand, was a bit temperamental. About once every 8 presses, the power button would not respond. Sometimes even when holding the button when attempting to reach the power menu, the tablet failed to recognize the press.
When a power button depress is recognized, the tablet lets you know with a short vibration. That's right, the Sero 7 Pro even includes a vibration motor, which also vibrates when things like the navigation keys are pressed. My unit had an internal rattle each time it vibrated, almost like something was slightly loose inside. It sounded peculiar and loud enough for a nearby friend of mine to take notice. Eventually, the rattle became enough to make me want to turn off vibration altogether.
These two issues are probably just quality control/manufacturing inconsistencies. I was out of the country while reviewing this tablet, so I unfortunately could not exchange it to see if a new unit would make a difference. While these problems were annoying, I wouldn't consider them deal-breakers -- especially when exchanging the unit at Walmart is an option.
The Sero 7 Pro display
The screen is definitely one of this tablet's strong points. Great viewing angles, HD resolution, and bright/vivid colors make watching TV and movies a pleasure. I put it through its paces with marathon sessions of The Office, Breaking Bad, and Game of Thrones, with no complaints. The handful of TegraZone games I played also looked great. The screen is on par with, if not better than, the one on my main tablet -- the Nexus 7.
The screen's glass has held up well to nicks as scratches over the time I've had it. When the tablet wasn't being removed from or returned to my backpack, it was spending time in my cargo pants pocket. While fingerprints did build up quickly, no permanent damage has been done to the glass so far.
The Sero 7 Pro software
The overall operating system is basically straight Android 4.2.1, just as Google intended -- with a few tweaks and some added apps. One of the first things that users who are used to on-screen buttons with the traditional setup will notice a fourth navigation button that has a "+" sign in the center. The sole purpose of this button is to take screenshots. This makes me wonder -- do people take screenshots on their devices so often that it warrants a permanent button in the navigation bar? Pressing power and volume down simultaneously takes a screen as well, and is already built into Android by default. The fourth navigation button seems like an unnecessary addition.
Making use of that extra black space in the navigation bar is all well and good, however adding a fourth button shifts the traditional three buttons (back, home, and recents) toward the left side of the screen. Those who are used to other Nexus devices may find their muscle memory tripping them up at first, missing intended buttons or taking screenshots instead of pulling up recent apps. I found myself constantly checking the buttons before pressing, being so used to Nexus devices myself. Those not already accustomed to soft keys probably won't notice. I do applaud Hisense for trying to make use of the wasted black bar space, even if it is to add a button that is a bit redundant.
The Sero 7 Pro is a Google-certified device, so it gets all the standard Google apps like Gmail, YouTube, Play Store, etc. The non-Chrome Android browser is also included, sporting Flash support. In addition to these, there are a few manufacturer and retailer apps as well: Walmart and Sam's Club apps, Vudu (Play Store alternative), Tegrazone, and Kingsoft Office. There is even a TV remote control app, however since the Sero 7 Pro lacks an IR blaster, a television must be hooked up to the same WiFi network as the tablet for the controls to work. Apps like Walmart and Sam's Club can be completely uninstalled, whereas TegraZone and Vudu are system apps and can only be disabled.
Hisense Sero 7 Pro Battery Life
The other main Android addition by Hisense is "Power saving mode." There are three available modes to control battery usage: Performance priority, Balanced, and Power save. This works by underclocking the CPU, extending battery life by handicapping the processor.
I had no problems getting great battery life, even in "Performance priority mode." Battery life is listed as 7 hours for continuous 1080p video playback, which about falls in line with my own usage. In Airplane Mode (because I was actually on a plane), I was able to watch sub-720p video for about 7 or 8 hours without killing the battery. In most senarios, battery life during actual usage was fantastic.
Standby time was another story. Over a 24 hour period, my tablet would lose up to a third of its battery life while in non-stop standby. This necessitated always having it plugged in when not in use, or making sure it was off while I was away. If I ever did happen to find the tablet dead from being in standby too long, it reached a full charge after being plugged in for 3-4 hours.
The Sero 7 Pro cameras
All photos seen above were taken with the stock camera app and default settings. Using another app or tweaking the stock settings would probably yield better pictures, but these photos seemed to come out pretty well regardless. The rear 5.0 megapixel camera performs well outdoors with plenty of light; indoor photos were also good, as long as things didn't get too dark. Quality goes downhill pretty quickly in low-light conditions. Hisense was kind enough to equip the Sero 7 Pro with a camera flash to help with closer objects in dark settings.
The biggest problem I had was with blurry shots, or blurry objects in sharp shots. When taking a photo, there is the stock Android animation of the snapshot jumping to life in the app, then sliding out of view to the right. Once this animation is completed, you would think that the photo-taking process was completed. However, the tablet needs to be held still for another second or two longer than expected, or the picture will come out blurry. Not a big deal -- it just takes a little getting used to. Another problem with blur that was more hit and miss was capturing moving objects. Sometimes even the slowest of objects, like pedestrians walking down the street, became blurs amongst an otherwise sharp and focused background.
Besides these minor issues, the rear camera is pretty decent once you get a little practice in with it. I got some great shots of different areas in Tokyo and Kyoto without too much effort. I wouldn't recommend this as anyone's main camera, but it is usable enough to be counted as a handy feature.
You can see my very handsome friend above posing for the front facing camera. It's a 2.0 megapixel shooter -- useful for the occasional self shot or Google+ Hangout. It works, which is about as stringent a requirement I have for front cameras. Being able to place a video call without my laptop is a definite plus (I admittedly don't have much use for the ability to take selfies).
The bottom line
The Sero 7 Pro does exactly what it sets out to do: offers good all round specs, more features than you can shake a stick at, and comes in at a great price. This isn't a tablet that most people would consider a major investment, but it is a very fun purchase. Casual users and first time tablet users will be amazed at how much Android you can get for $149. Even hardcore users who need a 7-inch tablet in the interim of waiting for the next big thing to come out will be happy with this purchase.
Hisense has managed to check almost every box for every user. Those who refuse to purchase a Nexus device because of the lack of expandable storage get a micro-SD slot, providing up to 32 GB more memory. Gamers that want access to NVIDIA-only games in the Play Store get a Tegra 3 processor along with 1 GB RAM. Movie watchers that want a portable device to hook up to their televisions get a mini-HDMI port that mirrors like a champ. Those that want cameras on the front and rear get both, along with a flash and all the stock-Android photo editing options.
Hardcore and power users should be wary, however. While the hardware features Hisense has included are numerous, the tablet does have last year's specs. With Tegra 4 seeing a widespread release soon, and 2 GB of RAM quickly becoming the norm, the Sero 7 Pro's hardware could be considered dated very soon. Hisense also has no major track record in the U.S. for Android updates, so it is hard to say if or when users can expect an update to Android 4.2.2 or beyond.
Buyers who do not need to be on the cutting edge of hardware or software will definitely find satisfaction with the Hisense Sero 7 Pro, both in the Android experience and their wallets.
