Galaxy S7 and S7 edge support both Marshmallow and Samsung fingerprint APIs
Though Android 6.0 Marshmallow doesn't bring a significant visual change to the Galaxy S7 and S7 edge, the under-the-hood improvements are definitely welcomed either way. And with this release, that means the new phones support Android 6.0's fingerprint APIs — so you can use a quick tap on the home button to unlock any app that has been written to accommodate Marshmallow's latest security feature.
What we didn't know up until this point is whether the integration of Marshmallow fingerprint support would cause problems with Samsung's own legacy fingerprint APIs, which have been around since the Galaxy S5 and adopted in a surprisingly large number of apps. Thankfully Samsung has managed to let the Galaxy S7 and S7 edge support both forms of fingerprint authentication at once, so no matter how your apps of choice want to be secure, the phones can handle it without issue.
Perhaps most important, it's completely opaque as to which APIs you're actually tapping into when the app surfaces the challenge for your fingerprint. Samsung? Google? Doesn't matter. Just wait for the prompt, put your finger on the home button and you'll be authenticated in short order.
Be an expert in 5 minutes
Andrew was an Executive Editor, U.S. at Android Central between 2012 and 2020.
