Best gaming controllers for Amazon Fire TV 2025
Take your Amazon Fire TV gaming to the next level with these excellent controllers.
Looking to invite friends over for a multiplayer session on your Amazon Fire TV but not sure what controllers are compatible? We've got you covered. Whether you have a first- or second-generation Fire TV, a 4K Fire TV dongle, or the new Fire TV Cube there is a variety of Bluetooth and wired game controllers worth checking out.
Thankfully if you already play games, you probably have at least one of these on hand already. Fire TV doesn't have a dedicated controller, so even something you already use like an Xbox or PlayStation model will suffice.
The best game controllers for Amazon Fire TV
Best overall
Amazon's Luna controller is a solid piece of hardware in itself, but it's also specifically designed to work with Amazon's game-streaming service. It's also compatible with most devices that use Bluetooth 5.0 or newer versions, meaning you can use it on your Android devices, your PC, or even other select brands of smart TVs.
Best for aligned stick users
Sony's DualSense Bluetooth Controller is a great option that's compatible with your Amazon Fire TV. It's quick to pair—simply go into the Amazon Fire TV's Bluetooth controller settings, then hold down the Create and PS button on the DualSense controller to start the pairing. In addition to PS5 and Fire TV, it's also compatible with Windows for PC gaming.
Best premium option
One of the great things about the Xbox Wireless controller is that it works with basically anything that has Bluetooth. Plus, it has a great look and feel that can stand up to hours of gaming. You can use batteries or pick up a rechargeable battery pack. It's that kind of versatility that can keep you in the game.
Best for mobile gamers
The SteelSeries Stratus+ is a great controller for just about any Bluetooth-friendly device in your life. Thanks to its lithium-ion battery, it has up to 90 hours of playtime on a single charge. It's perfectly weighted and has been designed to fit comfortably in your hands for marathon gaming sessions and even ships with a mount to hold your phone for mobile gaming.
Best budget controller
If you're on the go a lot, 8BitDo's line of Lite, Micro, and Zero controllers are all great travel companions, with the Zero being the smallest. It's absolutely tiny and can easily slip into your bag or even your pocket while you're on the go. The built-in battery is rechargeable with the included micro-USB cable. It's not the most comfortable controller thanks to its absolutely tiny scale, but you can't beat its portability.
Best for Switch owners
If you've picked up a dedicated Pro controller for playing on your Nintendo Switch, it's another viable option for hooking up to your Fire TV. Using familiar asymmetrical sticks, the controller itself is comfortable to use, and the superb battery life will last longer than anything else on the market.
Keep gaming on your Amazon Fire TV
It's tough to tell if Amazon even wants you to game on your Amazon Fire TV, but you sure can with the right accessories. It used to offer an official Amazon Fire Gaming controller, but that's essentially been discontinued. Amazon also seemingly scrubbed any help and how-to articles about pairing Bluetooth controllers from the Fire TV support page, but you should be able to get any of the controllers on our list to pair via Bluetooth. Gamers will always find a way.
Chances are, you might already have an older DualShock or Xbox controller kicking around your house to try out, or you could try and seek out a cheaper used version at a local gaming shop. If so, the DualSense is a great option, though you will need to mind the battery life.
Otherwise, our top recommendation is the SteelSeries Stratus XL because it has the classic layout that you're looking for in a gaming controller, long battery life, and it's great beyond the FireTV. You can pair this up with just about any device, including your Android gaming phone, and use it there too. It's really a great solution no matter where you're gaming.
Be an expert in 5 minutes
Samuel Tolbert is a freelance writer covering gaming news, previews, reviews, interviews and different aspects of the gaming industry, specifically focusing on PlayStation on Android Central. You can find him on Twitter @SamuelTolbert
