Best car mounts for Nexus 6P
The Best: ProClip for Nexus 6P
See at ProClipUSA
ProClip car mount
Finding a car mount for a big phone like the Nexus 6P is a challenge, but ProClipUSA has the answer with its ProClip car mount. It is specifically designed to fit its proportions, whether you use a case or not, and with many customization options for fit and charging, you're sure to find one that you'll love and join the thousands of satisfied ProClip owners worldwide.
Bottom line: If you want something that's sure to fit the oversized Nexus 6P, and if quality workmanship and customization options are important to you, then you can't go wrong with the ProClip car mount.
A closer look at ProClip
A Nexus 6P car mount customized for your vehicle and the way you drive
They are available in several different options, depending on whether you want to mount your Nexus 6P with a case or without, and whether or not you want to be able to charge it while it is mounted.
ProClipUSA's parent company and the manufacturer of ProClip mounts, Brodit AB has been helping people comfortably use their phones and other communication equipment in their cars for more than 30 years.
ProClip mounts are manufactured at the Brodit AB factory in Karlsborg, Sweden, where each mount is crafted from acrylonitrile butadiene styrene (ABS) plastic, rather than mass produced via injection molding.
They are available in several different options, depending on whether you want to mount your Nexus 6P with a case or without, and whether or not you want to be able to charge it while it is mounted. For charging, you have the option of using the 12V socket in your car or hardwiring it into the car's electrical system.
The only possible downside to the ProClip is that it does require some hardware installation with screws and a screwdriver. If you choose the option for hardwired charging, then you'll also have to get into your car's electrical system.
Regardless of the configuration, once installed in your car, you can easily slide your Nexus 6P in and out of the ProClip mount's cradle and position it at a 20-degree angle in any direction, and in either the portrait or landscape orientations.
Also great: Ram Mount Twist Lock Suction Cup Mount with Universal X-Grip
See at Amazon
The Ram Mount Twist Lock Suction Cup Mount attaches to either your windshield or dashboard with a suction cup and mounts and dismounts securely with a twist of the wrist. Its cradle is adjustable to fit large phones like the Nexus 6P, and its ball and joint socket system lets you position it in almost any direction.
Bottom line: Choose the Ram Mount Twist Lock Suction Cup Mount if you don't want to add anything permanent to your car's interior or bother with screws, and/or you want the option of mounting your phone to either your dashboard or your windshield.
Also great: Kenu Airframe+
See at Amazon
Kenu Airframe+
The Kenu Airframe+ fits securely in your car's air vents, so there are no screws and no adhesives to worry about. It's small enough to fit in your pocket, and when you're not using it in your car it becomes a stand for your Nexus 6P for reading or playing games, wherever you are.
Bottom line: If you don't want to bother with either screws or suction cups, try the Kenu Airframe+.
On a budget: TechMatte CD Magnet car mount
See at Amazon
Another option if you don't want to screw anything into your car's interior or mount anything to the windshield or the dashboard is the TechMatte CD Magnet car mount. It slips into your car's CD player and holds your phone via magnets. Priced at $10.99, it fits into any budget with ease.
Bottom line: The TechMatte CD Magnet mount is a good option if you don't want to bother with suction cups or screws, and you don't want to attach anything to your car's air vents. At $10.99, it's also priced affordably.
The ProClip Mount is the best!
See at ProClipUSA
Made specifically for the Nexus 6P, the ProClip mount is further customizable to suit your needs, whether you want a mount that you can use with or without a case, or whether you want to charge your phone while you're driving.
Bottom line: If you want a mount that you can be certain fits your Nexus 6P, and if you want a vehicle mounting solution that will last a long time, then there is no better car mount than ProClip.
Kathy McGraw
