AT&T partners with Rogers to offer LTE data roaming in Canada
![](https://cdn.mos.cms.futurecdn.net/QqfFjtSkTDddPcbMBqAhhF.jpg)
Same roaming plan structure gets you 120MB for $30
AT&T announced today that it has started a partnership with Rogers in Canada to offer roaming LTE data at the same rates it previously offered for lower speeds. Those "Data Global" add-ons weigh in at $30 per month for 120MB of roaming data, $60 for 300MB or $120 for 800MB. The only difference now is that when traveling in Canada, you can burn through those relatively small data caps faster with access to the Rogers LTE network.
If it was going to partner with any carrier for the widest LTE network and fastest speeds, Rogers was probably the best bet for AT&T. The carrier claims that 70 percent of Canadians now have access to the Rogers LTE network, with 95 new LTE markets going live just this year. It's a far cry from unlimited free roaming offered by T-Mobile in over 100 countries, but for those who jump up to Canada often the access to LTE will be important.
Source: AT&T
Be an expert in 5 minutes
Andrew was an Executive Editor, U.S. at Android Central between 2012 and 2020.
