Though ASUS sells a ZenFone 2 Laser in multiple regions around the world, it actually comes in a couple different configurations. In the U.S. we get the ZE551KL model, which is actually quite different from the international model. It has a larger screen, and higher-end specs all around. Here's the full spec sheet.
Qualcomm Snapdragon 615 octa-core 64-bit at 1.7GHzAdreno 405 GPU
Storage
16 or 32GBSD card expandable up to 128GB
SIM
Dual Micro SIMLTE on both SIMs
RAM
3GB
Rear Camera
13MP, laser autofocus, f/2.0 aperture5 element Largan Lens, dual LED real tone flash
Front Camera
5MP, f/2.0, 85 degree wide angle lens
Network
GSM/EDGE: 850, 900, 1800, 1900 MHzHSPA+: 850, 900, 1700/2100, 1900, 2100 MHzWCDMA: Band 1/2/4/5/8FDD-LTE: Band 1/2/3/4/5/7/8/17/20Cat 4 LTE up to 150 Mbps, DC-HSPA+ up to 42 MbpsDual antennas
Connectivity
802.11n Wifi, Bluetooth 4.1 with AptX, Wifi Direct
Sensors
GPS, BDS, GLONASS, accelerometer, ambient light, proximity, e-compass, HALL sensor
Battery
3000 mAh Li-PoRemovable
Charging
Micro USB
LED notification light
Yes
Dimensions
152.4 x 77.2 x 10.9 mm
Weight
170 g
Be an expert in 5 minutes
