Score an Anker Qi Wireless Charging Stand or Pad at more than 40% off
Two of Anker's Qi Wireless Chargers are becoming more affordable than ever, though you'll need to use the appropriate promo code below to score the lowest possible price. Both options are now down to $12.99 and more than 40% off, so choose which fits your needs best and hit checkout before these discounts disappear.
Anker's PowerPort Wireless 5 Stand is easily the most efficient option, which falls to $12.99 with promo code IWSTQM9B. It allows you to keep your phone charging wirelessly while angling it towards you so you can continue using it for video calls, watching YouTube, or reading notifications as they come in. It offers a 5W charge for every device and has protections against overvoltage, foreign objects, and overheating. It's highly reviewed, too.
Meanwhile, the Anker 10W Wireless Charging Pad won't face your device towards you, though it can charge compatible devices twice as fast so you can remove your device from the charger much quicker. Only the latest Samsung devices can charge at 10W, while every other device will charge at 5W, so it's not going to make much of a difference if you're not a Samsung user. This model also drops to $12.99, though you'll have to use the code SDQH2512 instead.
Alex Smith
