3 Affordable Alternatives to the Samsung Wireless Charger Duo
Samsung's new Wireless Charger Duo is an elegant solution to an inelegant problem: having to charge multiple phones (or a phone and a watch) at the same time overnight. Rather than using two different chargers, you can buy this one big pad that has an angled stand on the left and a flat segment on the right. The problem is you pay for that simplicity: the Wireless Charger Duo is $115, which is more expensive than buying two separate chargers! You'd think you'd get a discount. Thankfully, there are alternatives out there.
We don't blame you for not wanting to pay big money for Samsung's Wireless Charger Duo, so you can save by going with one of our picks instead. The ZENS dual wireless charger will give you the best and most Samsung-like experience for about $35 less, which is great savings. However, you can save even more by getting a less expensive dual charger, or just run your own by getting two small and inexpensive wireless chargers.
Andrew Martonik
Andrew was an Executive Editor, U.S. at Android Central between 2012 and 2020.
