Accessory review: Seidio SURFACE Case for HTC Incredible 2
HTC Incredible 2 owners who are looking for a robust case for their phone should check out the Seidio SURFACE Case.
The case comes in two pieces that fit together. Sometimes with accessories like this, they easily fall apart or don’t stay put as long as you might hope. Often this can be caused by poor design and/or frustration when trying to fit together the case and one piece breaks off. This is why I was skeptical of Seidio's case at first. After spending a lot of time with it however, it has exceeded my expectations. Not only has it remained in place, but I actually had trouble getting it off the phone.
Seidio has continued with their excellent protective material with this case. At just 1mm thick, you know it won’t had a ton of extra bulkiness to your phone.
If you’re interested, you can pick up the Seidio SURFACE Case from the Android Central Store for $27.95 in black, sapphire blue, burgundy or amethyst.
Be an expert in 5 minutes
